Thread: Warning light on dash orange with key on it
Results 1 to 10 of 13
  1. Warning light on dash orange with key on it
    Mar 2007
    Manchester
    when i try to start my car which is an A4 Avant Quattro (1996) the light flashes which is situated on the rev counter side of the dash the light is orange/amber in colour whith a car shape on it with a key symbol on it now it flashes and car starts then cuts out so im sure its to do with the alarm/imoboliser side of things and i have to turn key off and on for a few minutes then it comes on and goes out then car starts and runs fine is this a problem with the key or alarm or something else any help would be great
    thanks johno
    May 2007
    You are correct in your assumption that this relates to your immobiliser. Are you using an original, dealer-supplied key, or a replacement?
    May 2007
    St Ives Cornwall
    Have a look at this link....
    https://www.vwaudiforum.co.uk/forum/showthread.php?t=8761
    They have a similar problem
    mcc
  4. Exclamation yup...
    May 2007
    NorthWest
    i been having the same problem for months.
    what i did (yesterday) was to go and buy some electrical contact cleaner from a local car accesories shop. carcraft and halfords do not supply this supply this. bms do, but it is overpriced. (£6.99). also it would help to buy a new battery (£2-bms, £3.59-halfords)
    then open up your key, take out your battery and spray the whole thing and give it a wipe down, also spray your barrel and the actual key (with the cut design) on it both sides. replace your battery with the new one.
    this has reduced the problem and saved me a lot ov headache. it used to flash (immobilser) approx 15-20times a day ( i do a lot of start-stop driving). so far since yesterday its only come on twice.
    Electrical contact cleaner (varys in price between £3.50-£6.99)
    Car key light battery ( varys in price between £2-£3.59)
    A cloth (am sure you got a clean one lying about)
    A penny. (to open your key, insert the penny into the dip in the side of your key, and twist to pry open)
    thats all i did and used, after getting the advice from fellow audi owners on this forum.
    Apr 2007
    Lancashire
    This is generally the reader coil for the immobiliser playing up.
    It loops around the ignition barrel, and gets pulled when the steering column is adjusted, causing a bad contact or damage to the wire.
    Mar 2007
    Manchester
    yes its the orignal key but i used the spare (with a spanner on it whats this key forapart from the normal thing)and the light has not come back on as yet but will try the clean it method and i have had the dash apart replacing some bulbs backlights god they make them hard to replace dont they
    cheers all johno
    Apr 2007
    Lancashire
    The key with the spanner symbol on it is the workshop key, it should disable the immobiliser but wont open the glovebox.
    You may also have another key which only opens the doors but wont work the ignition.
    The main keys and the tiny plastic one all are fully functional in all locks + ingition.
  8. Angry
    May 2007
    NorthWest
    Argh that <removed, see reason below> piece of junk immobilser has started playing up again!
    not only do i need it to start the damn thing, but i get overboost/underboost quite a bit, so i gotta re-start the car sometimes ( if i dont want it to drive like a HGV)
    errrrrrrrrrrr............
    help?>
    Last edited by Sam; 19-06-2007 at 09:41 AM. Reason: expletives removed - no need to swear quite so much
    Mar 2007
    Manchester
    the key with the spanner seemed to fix my problem touch wood not had it since using this key
    johno
  10. Re: Warning light on dash orange with key on it
    Near Blackpool
    48 Post(s)
    I just unplugged battery and plugged it in again.. problem solved... my MK4 Golf did the same years ago and that fixed that aswell... guess the immobiliser just gets a bit confused.... must be made my microsoft ;-)
  1. warning symbol on dash?
    By Yosemite Sam in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2008, 07:37 PM
  2. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  3. dead dash light?
    By leckford in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-05-2007, 11:58 PM
  4. Warning icons on dash?
    By paul46 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-05-2007, 07:46 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
