Thread: golf mk5 hard to start
Results 1 to 8 of 8
  1. golf mk5 hard to start
    May 2010
    Dungannon Northern Ireland
    hi,i have a mk 5 golf 2005 1.9tdi 105bhp,i am having problems with starting the car when hot.i would crank the car over about 10-12 times before the engine would fire.i have replaced numerous engine coolant temp sensors an this hasnt fixed the prob.i brought the car to my local VW dealer they ran diagnostic tests,an came up with the answer that the car requires a starter motor.the car starts perfect when cold,it only gives this problem when hot.the dealer had disconnected the wire going to the engine coolant temp sensor and the car started normally.does anyone no what the problem may be? thanks J.Burrows.
  2. Re: golf mk5 hard to start
    Aug 2009
    ireland
    sounds right had the same problem with my 05 golf tdi, the problem is the engine doesnt have to crank so fast for a cold start as it does for a hot start hence when u disconnect the sensor it thinks its cold and starts faster. i didnt replace my starter i just reconditioned it cost me €70 and its 10 times better but still not perfect. for a hot start the engine has to be cranking between 270-280 rpm,mine was at 200 before its cranking at 250 now hope this helps. oh and i also had the temp sensor replaced, didnt do a thing to help.
  3. Re: golf mk5 hard to start
    May 2010
    thanks for the help,v much appreciated.a starter is £150+vat i didn wana put the £ into it if it didnt cure the prob,as vw wont take back electrical items.
  4. Re: golf mk5 hard to start
    Jun 2008
    I have much the same problem and did you change your starter and did it cure problem
  5. Re: golf mk5 hard to start
    May 2010
    im fitting my starter tomorrow night il keep you posted if this cures the problem.fingers crossed...
  6. Re: golf mk5 hard to start
    Leics
    I'm pretty sure you'll find it cures it.
    Good luck.
  7. Re: golf mk5 hard to start
    May 2010
    hi,i fitted a 2nd hand starter of my friends golf,same car as mine.put it on its 10 times worse than my own.so i sent my own starter away got it rewound an all that the starter needed.fitted it today and its a vast improvement to what it started like before.so hopefully fingers crossed it'l stay like that.thanks for the help.
  8. Re: golf mk5 hard to start
    Mar 2008
    Can anyone please advise on the following fault code.
    The problem is when the car has reached its normal temp and then you start it again theres a delayed response 5-8secs takes a few good cranks
    Diesel – Direct Fuel Injection/Glow Plug system w/p
    03G906016CB
    R4 1,9 EDC G000SG
    Coding 71
    Dealer number 01392
    02810111900
    345
    6176
    I have replaced all 4 glow plugs issue still there
  1. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 17-09-2009, 08:43 AM
  2. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 15-09-2009, 08:29 PM
  3. golf TDI 110 are they normally hard to start
    By sidewayz in forum New Member Introductions
    Last Post: 19-10-2007, 06:00 PM
  4. First Facts on the Golf BlueMotion:
    Last Post: 13-08-2007, 07:08 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
