Thread: Would the N75 valve cure the limp mode problem?
Results 1 to 10 of 16
  1. Would the N75 valve cure the limp mode problem?
    Jul 2008
    Bristol
    I have done some research but found no luck, I was thinking to replace the N75 valve with a new one. The car went on limp mode again today, could not go past 100mph!!
    Can anyone shine some light?
    EDIT: Where is the N75 Valve located? The car is a 1.9 TDI AWX (130pd) 2001.
  2. Re: Would the N75 valve cure the limp mode problem?
    Apr 2009
    First thing first....Get the error codes read
  3. Re: Would the N75 valve cure the limp mode problem?
    Jul 2008
    Bristol
    Quote Originally Posted by accy View Post
    Im 100% sure it is the N75 Valve causing the car to go on limp mode. When the car was replaced with new engine mounts the Indi told me that I need to replace my Boost control switch/valve (replaced last year). But I never took any notice of it, until now!
  4. Re: Would the N75 valve cure the limp mode problem?
    Dec 2007
    to be quite honest it could be anything you maybe wasteing cash and time on that get a scan
    i travel to wales every weekend so if u want ill meet u at a services an scan for u on my way down ill be that way around 10am saturday
  5. Re: Would the N75 valve cure the limp mode problem?
    Jul 2008
    Bristol
    Update:
    I did some thorough checks on the pipes and it seems to me, that the pipe has been slightly melted.
    Here are the pics:
  6. Re: Would the N75 valve cure the limp mode problem?
    Jul 2008
    Bristol
    Quote Originally Posted by bez101 View Post
    Hey Bez101,
    I guess your right, wasting all that money and find out thats not even the problem. That seems like a good idea, but I don't want to yes right now I might be busy on the weekend.
    I will PM you by Friday morning and let you know!
  7. Re: Would the N75 valve cure the limp mode problem?
    Mar 2010
    notts u.k
    Definately DONT buy a new N75 valve without a diagnostic scan first preferably with VAG COM i would take bez101 up on his offer at least you are 100% sure what the fault is then.
  8. Re: Would the N75 valve cure the limp mode problem?
    Mar 2010
    notts u.k
    just seen your pics if that is worn right through on that intercooler/boost pipe that will cause limp mode as the boost pressure wont be right.sorry for above post didnt see you had responded when i hit reply got side tracked halfway through posting
  9. Re: Would the N75 valve cure the limp mode problem?
    Jul 2008
    Bristol
    Quote Originally Posted by matta4 View Post
    No worries Matta4. I did felt/touched the melted intercooler/turbo pipe and it seemed to me that it has gone through right in.
    1) How much would it cost to get the whole pipe replaced?
    2) Is there a cheaper way of fixing it?
    If not, then where can I get the intercooler/turbo pipe? I had a look on ebay and seen only 1 thats going for £80!!
  10. Re: Would the N75 valve cure the limp mode problem?
    Sep 2008
    chester
    17 Post(s)
    Have repaired intercooler pipes before with a metal insert (to the correct internal diameter) and two jubilee clips, difficult to see by your pic if its in a straight section,otherwise your into a bent section, maybe try the breakers!
  1. Overboost and Limp Mode problem solved.
    By Big G. in forum Golf MK4 - 1999 - 2004
    Last Post: 15-08-2019, 08:44 PM
  2. A4 1.9 tdi in Limp Home mode after high power.
    By saidtheape in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2009, 01:10 PM
  3. Limp mode
    By Stueyboy1989 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2009, 05:59 PM
  4. HELP! Still got 'limp' mode (losing power) after paying £200!!!
    By Smalls in forum Touran - Sharan - Caravelle
    Last Post: 08-04-2009, 10:28 AM
  5. Can anyone help me???
    By GreatGig in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-09-2007, 08:38 PM
