Thread: 01772 - Signal from Level Control Pressure Sensor (G291)
  1. 01772 - Signal from Level Control Pressure Sensor (G291)
    May 2008
    Cork,Ireland.
    Pulled up this code tonight and am a bit stumped as everything "seems" to be working,any ideas?
    2000 Audi allroad 2.7t bi-turbo quattro
    1987 Audi Coupe quattro
  2. Re: 01772 - Signal from Level Control Pressure Sensor (G291)
    Jun 2008
    My advice
    If it aint broke then dont try and fix it!!! lol
    Give bagpipingandy a shout, he should beable to shed some light on it.
    Lee
    2001 Allroad 2.7 Bi Turbo Quattro
    1998 A6 2.4 SE Avant
  3. Re: 01772 - Signal from Level Control Pressure Sensor (G291)
    Sep 2009
    A406
    01772 - Signal from Level Control Pressure Sensor (G291) 27-10 - Implausible Signal - Intermittent
    #or
    01400 - Suspension Level Control 11-10 - Control Limit Not Reached - Intermittent .
    Any of the corners sagging over time? Hear compressor running more often and louder?
    G291 sensor is the internal to the valve block mounted on the compressor bracket. It is the unit with the six air lines going to it as well as a 10 pin multi-pin connector under the car.
    Looks like is either loose wireing or compressor is getting tired and strugling to maintain required pressure.
    Quite common fault in older Allroads ecu . It doesnt necessary mean it will fail soon, mine's got it for at least two years now....
    V6 Tdi Power!
  4. Re: 01772 - Signal from Level Control Pressure Sensor (G291)
    Ayrshire, Scotland
    18 Post(s)
    Is the fault intermittent?, does it light up the level fault light in the dash?
    As all-rod, check 10 pin connection on valve assembly, this pressure senser (G291) is located there and is connected via 10 pin connector to ECU (J197) in LH side of Boot compartment, so check connections there also.
    Hopefully its intermittant and does not show up too often
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  5. Re: 01772 - Signal from Level Control Pressure Sensor (G291)
    May 2008
    Cork,Ireland.
    The fault is intermittent and does not display the level fault light in the dash.....have not had a chance to get under the car and will check the ECU in the boot and will then check back in here.
  6. Re: 01772 - Signal from Level Control Pressure Sensor (G291)
    Jan 2014
    Leicestershire
    Quote Originally Posted by bagpipingandy View Post
    Dragging an old topic back up but where exactly is the J197 ECU? I've looked in the rear left panel, there's the toolkit and the pressure accumulator - not seeing much else? Do the interior trim panels have to come off? Or does it become obvious when you take out the cage that holds the toolkit? FWIW the opposite side panel is filled with Bose amp and subwoofer.
  7. Re: 01772 - Signal from Level Control Pressure Sensor (G291)
    Ayrshire, Scotland
    18 Post(s)
    Hi, the module is behind the carpet side panel, to access it you need to remove the full LH side panel in the boot
    best Regards
    andy
  1. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  2. Household water - A puzzle!
    By stuart in forum Chat - Completely Off Topic
    Last Post: 09-02-2010, 09:51 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. The performance SUV Audi Q7
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
