Thread: How do I replace side light bulb?
Results 1 to 9 of 9
  1. Question How do I replace side light bulb?
    Oct 2009
    Wiltshire England
    Hello people,
    My near side side light bulb in knackered so I bought a new one to replace it with, however I have noticed that the access to the bulb is tight.
    I removed the rubber cover from the back of the headlight however I'm not sure how to remove the bulb, I can kind of feel the bulb and where the wires go on to it but I don't want to force anything.
    How do I remove this bulb to allow me to replace it?
    I know this is a simple question however I just do not want to damage anything.
    Cheers,
    Dan
  2. Re: How do I replace side light bulb?
    daniel408 Guest
    With great difficulty. I have just changed both of mine and i found the near side one is a lot harder. I managed to get a pair of long nose pliers in there. Make sure you are happy that you have a grip on the bulb holder and not the wires, last thing you need will be that.
    They don't make it easy!!
  3. Re: How do I replace side light bulb?
    Oct 2009
    Wiltshire England
    Cheers for the reply, I'll have a look under the bonnet some time soon.
    Thanks,
    Dan
  4. Re: How do I replace side light bulb?
    jonda Guest
    i pulled the wires, eeek.
    i know i wasn't sposed to but... it worked.
  5. Re: How do I replace side light bulb?
    Jul 2008
    Norfolk, U.K.
    Having read this thread , am I right to assume that the holder simply "pulls" out and does not need to be turned ?
    I want to replace both of mine and obviously the last thing I want to do is break any of the wires
  6. Re: How do I replace side light bulb?
    Oct 2009
    Wiltshire England
    I still have not changed my bulb yet, I would also like to know is the side light bulb holder a pull out or is it a twist and pull job?
    Cheers,
    Dan
  7. Re: How do I replace side light bulb?
    May 2010
    Devon England
    as said they just pull out, there are flats on the bulb holder to grip on to, there are tight but do come out ok
  8. Re: How do I replace side light bulb?
    Jul 2008
    Norfolk, U.K.
    Well , wnet thr "pliers" route and got them out eventually.
    Tight but came out ok.
    Job done
  9. Re: How do I replace side light bulb?
    Sep 2007
    Bath, England
    Managed to get by meat hooks in there eventually, honestly thought about selling the car and buying a new one with working sidelights. Cheers!
  1. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  2. Side light and indicator/hazard problem
    By Jock Doc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-05-2010, 11:08 AM
  3. Side lights show on high level brake light?
    By joeb in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 10:15 PM
  4. brake light bulb!!!!
    By jjt5 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2007, 11:09 PM
