Thread: Passat b5.5 front brake use audi a4 b7 ?
  1. Passat b5.5 front brake use audi a4 b7 ?
    Jul 2009
    singapore
    Hi guys
    I had the stock front calipers with brackets...
    Changed to brembo-used... Now it has a screeching sound
    each time I step on brake at low speed....high speed hardly can hear
    thinking of swapping to audi a4 b7 cos got a friend selling cheap
    can the audi a4 b7 brakes with bracket fit ?
    Or
    how to remove the screeching sound ?
    Ps when car is cold moving off no sound ... As it goes through the day...
    Possibily with heat and expansion then the sound comes
    any advise ? Thanks in advance
  2. Re: Passat b5.5 front brake use audi a4 b7 ?
    Gwent
    Some/All? A4 B6 models use an Alloy wheel bearing carrier, where the passat B5.5 has a steel one. Due to the change in material. The brake caliper brackets use a different mounting hole spacing. I think the B7 A4 is likely to also use the alloy part..
    You may cure the squealing by adding a smear of copaslip grease to the back of the brake pads?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Passat b5.5 front brake use audi a4 b7 ?
    Mar 2009
    Remove pads, chamfer an edge all round each pad braking surface and copper grease the backs. Replace pads = squeal gone.
    No idea about the Audi brakes.
    I came in to this world with nothing and I've still got most of it left.
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. Aluminium a5 coupe prototype shows the lighter side of audi
    Last Post: 04-10-2009, 02:16 PM
  4. Record results for vehicles sales, revenue and profit
    Last Post: 12-05-2007, 08:33 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
