Thread: HELP! DVD in headrests - how to run cables through seats?
Results 1 to 10 of 11
  1. Unhappy HELP! DVD in headrests - how to run cables through seats?
    Apr 2010
    Hi there,
    I have got an A6 C5 estate and I have bought 2x 9" monitors with DVD players. all the cables are going through the headrest poles and I need to run them through the seats. I tried to run a draw wire, no success.
    Is there any easy way to run the cables from the headrest poles to the bottom of a seat? Do I need to unbolt the seat from the car? Can back part of the seat (with small items net) can be disconnencted somehow from the main seat?
    Kindest regards
  2. Re: HELP! DVD in headrests - how to run cables through seats?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Big Col did a detailed writeup of how to retro-fit seat heaters in his A6 C5 Avant a while ago. If memory serves, he included pics of how the seats could be dismantled, which may give you some pointers to what's required to get your cables installed in the seats.
    His original post is here: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=79203
    Good luck!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Red face Re: HELP! DVD in headrests - how to run cables through seats?
    Apr 2010
    Thank you MFGF.
    The other thread have helped me a bit, but I want to avoid seats removal if possible, still looking for an answer...
  4. Re: HELP! DVD in headrests - how to run cables through seats?
    The rear of the seat is removeable with the seat in the car. PM me your year and model and seat type and your email address and I'll send you the data. Regards Peter
  5. Re: HELP! DVD in headrests - how to run cables through seats?
    Apr 2010
    Quote Originally Posted by Peter D View Post
    Hi mate, thank you for reply.
    I have less than 10 posts, so I can't send PMs yet. Sorry!
    I have got an Audi A6 estate, 2001 pre-facelift model with 1.8T 150KM and manual 5 speed gearbox. The front seats don't have the lumbar support, just electric height adjustment and tilt on the big knob. There are airbags in front seats. Im hoping these are all the data you will need.
    Thank you for your support
  6. Re: HELP! DVD in headrests - how to run cables through seats?
    Check your email.
    Edit your post and remove your email to avoid Phishing.
    Regards Peter
  7. Talking Re: HELP! DVD in headrests - how to run cables through seats?
    Apr 2010
    Check your email.
    Regards Peter
    I have received it, this is what I was looking for. I knew that Audi used that stupid clips which are so easy to break, but now I know where they are - so it should not be too difficult.
    I also removed my email address. Thank you for reminder - and first of all - for a professional approach to my problem. I will write a PM and a post in here to let you know if I was successful.
    Regards,
    megalanca
  8. Re: HELP! DVD in headrests - how to run cables through seats?
    Oct 2010
    Hull , UK
    I have a 2004 Audi Avant and have just purchased some of these DVD headrests and would be gratefull how to take the seat back off as well , mine has the net on the back of seat also.
    Regards Mike
  9. Smile Re: HELP! DVD in headrests - how to run cables through seats?
    Apr 2010
    Hi Mike,
    Basically you have to get head down in rear footwell, take a light out off the seat than pry the back of a seat off gently and look for a yellow clips - torch will came in handy - then unclip them with small flat head screwdriver, once done get out and pull seat backing right down. Assembly in reverse order.
    Pm me with your email address for a schematic drawing
  10. Re: HELP! DVD in headrests - how to run cables through seats?
    Oct 2010
    Hull , UK
    Thanks for your reply , my e-mail is
    michael@centurionway.karoo.co.uk
    if you could send me a diagram please .
    Regards Mike
