Thread: VW T4 2.4 (94) Strange Gear Change Problem
  1. Angry VW T4 2.4 (94) Strange Gear Change Problem
    May 2007
    I NEED
    I seem to have a strange intermittent problem with changing gears on my transporter. When the engine is cold - 1st & 2nd gear are REALLY hard to get into & will only just go in if the Clutcfh pedal is right to the floor. And all the other gears are quite stiff too.
    However, once I get it going (5-10 mins driving or so) the problems gets much better, with gears 1,2 & 3 still a wee bit stiff, but not bad............ any ideas?
    PS There's seems to be no clutch slipping or power loss, no strange noises etc??? Any help/ideas really appreciated!!
    May 2007
    london
    i think that it could be the gear selector linkage. mine had a similar problem and the nice man from the AA repaired it - parts were only about £6 from a main dealer. mine stil has issues going in to 1st as the gear change is even tighter now. with mine i have to push it quite hard to the left as if i was going in to reverse (but obviously not pressing down on it) then it slips in to place Ok - a bit of getting used to but once yiu get the hang of it its fine.
  3. Re: VW T4 2.4 (94) Strange Gear Change Problem
    Auckland N.Z.
    Had similar problem. Check gear oil spec. I use BP 80w90 LHC. Also these symptoms have shown as early sign of slave cyl failure. Best of luck. John
  1. Strange Signal Problem
    By VWLeonG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2010, 09:30 PM
  2. stiff gear change - passat V6 4motion
    By richards in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2009, 11:32 PM
  3. a6 4.2v8 steering wheel gear change
    By tianala in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-02-2008, 02:37 PM
  4. VW gear knob removal? change gaitier
    By Z Man in forum Passat - Archive Topics
    Last Post: 30-11-2006, 09:51 AM
  5. strange problem..
    By reenoo in forum Polo - Derby - Lupo - Fox
    Last Post: 26-08-2006, 05:07 PM
