Thread: Air vent light
Results 1 to 10 of 11
  1. Air vent light
    May 2009
    Hassocks, West Sussex
    Hi I have a 2002 Passat 130 TDi sport, the air vent on the dash are illuminated around the contol dials that open and close the vent.
    My problem is that some do not work and I can'nt find out how to replace the bulbs, do the vents just pop off or is it a dash out job or are they non replacable.
    Kind regards
    Pokey
  2. Re: Air vent light
    Quote Originally Posted by Pokey View Post
    Kind regards
    Pokey
    They can be removed using a couple of butter knives to prise them out of the dash, the lamps can be replaced, I replaced mine with LEDs
  3. Re: Air vent light
    Dec 2008
    Did mine as well recently and it aint that easy to get the vents out. Dam wish id put leds in thats a realy good idea will last 4ever
  4. Re: Air vent light
    May 2009
    Thanks I found some other posings, I went to VW and the parts manager told me their were no bulbs in the vent!!!!
    After making him look them up their are 3 at £4.86 each, I would think their is 4.
    Would love to do the LED's but does any one know what resister to use.
    I think the LED's are 5v so need to drop 7 volts.
  5. Re: Air vent light
    Just use 12V LEDs, I used something like these,
    Ebay item No 320514682703
  6. Re: Air vent light
    Norfolk
    LED voltage drop depends on colour. White is about 3.5v and needs a half watt resistor of about 470 ohms in series. LED's and resistors are cheap if you have a Maplins store near by.
  7. Re: Air vent light
    Apr 2010
    portadown UK
    Be carefull.
    Wrong value resistance or wattage resistor and you will burn out the resistor and/or LED!
    Check these out.
    http://homepage.ntlworld.com/michael...mson5/ledcalc/
    http://www.ledcalculator.net/
    http://www.electronics2000.co.uk/cal...calculator.php
    http://www.ee.ucl.ac.uk/~amoss/java/calcled.htm
    and there are many more,search for LED series resistor calculator.
  8. Re: Air vent light
    Quote Originally Posted by Intelicide View Post
    Be carefull.
    Check these out.
    I must be missing something here, 12V LEDs work out to 3.5 pence each, why go to the trouble of calculating resistor required, soldering it to the LED (which probably cost more!) then finding out there is no room to fit the result?
  9. Re: Air vent light
    Norfolk
    I agree with you Caldirun. It makes more sense to buy a ready made product. If you make it yourself you do have more control over the LED performance and the wattage of the resistor. I think the best thing to do is find a supplier that you trust and stick with them. There is a lot of crap on ebay.
  10. Re: Air vent light
    Apr 2010
    portadown UK
    Quote Originally Posted by caldirun View Post
    ......... why go to the trouble of calculating resistor required, soldering it to the LED (which probably cost more!) then finding out there is no room to fit the result?
    If you do not use correct value resistor,the LED may end up too dim or too bright(too bright=short lifespan).Either way you will have the hassle of removing the vents again,which are easily broken.
    This mod is very simple and the parts will easily fit.
    As to why bother?
    Some guys just like to tinker with things,maybe make them better,just for fun...
  1. sharan air bag light on.
    By dan rivers in forum Touran - Sharan - Caravelle
    Last Post: 08-03-2011, 12:03 PM
  2. Please Help Dashboard Cluster issues, rev counter, oil light and speedo
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2009, 11:31 AM
  3. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
  4. Air vent removal
    By RoorsT5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-07-2009, 08:56 PM
  5. Air Bag light issue
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-05-2007, 06:57 PM
