Thread: HELP! Flywheel troubles!
Results 1 to 10 of 13
  1. HELP! Flywheel troubles!
    May 2007
    Little Houghton, Barnsley, United Kingdom, United Kingdom
    Hi guys this has been ongoing now for sometime but iv only just about saved up enough money to buy a new flywheel but now it gets confusing!
    I have a Mk4 Golf gt tdi 'gti' 150bhp ARL engine
    Im wanting a single mass flywheel conversion as im going to get a remap to 206bhp (or there abouts) and appently the original duel mass flywheel and clutch can only stand 180bhp, which will no good to me, does anyone know the actual figures of what a duel mass flywheel and clutch set can handle?
    id still perfer a single mass even if the duel mass could stand 200+bhp as then i can get rid of the exspensive problem of it going again but for my engine the single mass flywheels are like gold dust to come by and when i have found one they want way over the odds for one.
    Can some pleeease help !!
  2. Re: HELP! Flywheel troubles!
    Quote Originally Posted by e6m6a6 View Post
    A standard DMF for the 6 02m speed box will handle 400nm + of torque if driven correctly. Since your are mapping to over 200bhp this will be giving you over 400 mn of torque so therefore you will need and uprated clutch to stop slippage, the standard clutch WILL NOT HOLD over 400nm. You would get away with a DMF as long as you develop a religious habit of not flooring it at low rpm in anything higher than second gear...
    I knew of a guy who was running a tdi 130 with a turbo dynamics MD 376 turbocharger, FMIC,uprated SACHS clutch and a DMF. The car was putting out 240 bhp and near 500nm. The DMF lasted fine because he drove as I explained above...
    A solid flywheel sounds horrid when the car is idle and the clutch released.... And plus it will allow more vibration into your gearbox causing more wear...
    The choice is yours... Reliable power will cost you. Ever consider a 1.8t AUM... A remap alone will see 220bhp with one of those
  3. Re: HELP! Flywheel troubles!
    Jan 2010
    New Haw, UK
    I am curious. What does the gear have to do with flooring it? I thought the flywheel/clutch is at the engine end of the gearbox (pre-gearing), and the engine puts out the same power/torque regardless of the gear. So why would the clutch cope any better with flooring in fourth compared with flooring in first?
  4. Re: HELP! Flywheel troubles!
    May 2007
    thanks for help gbrad2x
    dont suppose know any websites where i could buy a uprated clutch to suit the engines needs?
    i cant seem to find much for my engine code
    thank you
  5. Re: HELP! Flywheel troubles!
    thank you
    for the DMF Id go with
    http://www.eurocarparts.com/ecp/c/Vo...5ba0dcb79&DMFW
    For the uprated Sachs with release bearing Id do with
    http://www.jabbasport.com/store/inde...CK6SPDSACHSTDI
    Jabba also have the above kit with a Solid flywheel but your car will sound like it has something wrong with it IMO,they sound terrible
    Not much else I can help you with I think
    PS . Dont forget to investigate the site sponsors on here , they may well be cheaper again!
  6. Re: HELP! Flywheel troubles!
    Quote Originally Posted by RobWithey View Post
    Water is wet, the sky is blue and 1.9 TDI DMF's will self destruct when you floor it at low revvs in a high gear on a car thats remapped
  7. Re: HELP! Flywheel troubles!
    May 2007
    Thankx for all your help gbrad2x
  8. Re: HELP! Flywheel troubles!
    Oct 2009
    manchster
    Quote Originally Posted by gbrad2x View Post
    as im learning in my 204 bhp remapped pd 150 tdi, the torque is so awesome even in 6th gear i just had too much fun outdragging the motorway bmw's merc's and audis who think they own the 3rd lane..... too easy
    sachs organic race clutch and new dmf will be going in my car next, im in the early stages of failure ... noticable at about 2500 rpm in 4th and above when i FLOOR it the revs jump ahead of the correct speed by about 500 rpm then hover untill my gear catches up with the revs.
  9. Re: HELP! Flywheel troubles!
    May 2007
    Quote Originally Posted by rs250gpracer View Post
    its very rare i fell the need to floor my car, after going from a 1.4 polo to the 150pd iv learnt to use my gears other then power to overtake people so 90% of the time i use no more then half throttle, the other 10% of the time been little boyracers in there saxo's....thats just insulting when they think they can beat me!
    so im still confused, so right now im after an after market clutch and flywheel? as she going to be sat at 206bhp as soon as i have the time to do it!
  10. Re: HELP! Flywheel troubles!
    Oct 2009
    manchster
    oh i know all about using my gears mate, my last car was a subaru turbo i also spent 4 years on tracks in the uk racing a 250 cc 2 stroke grand prix bike (honda rs250 gp bike upto 165 genuine mph).
    once you remap your golf u will find yourself driving about the roads 1 gear higher than now ... this is because 4th will now pull just like 3rd ... from low speeds, this means once on the motorway there is hardlly any need for any other gear apart from 6th !!!!!! and with so much torque there is no need to drop down to 5th for anoything other than racing with a ferrari
    however ..... using this torque from low revs in high gears will destroy your dmf. the racer instinct inside me cant accept some1 overtaking me on the motorway .... once i fit my new dmf and clutch i guess i will start dropping a gear simply so my revs are not so low before i floor it ... .saving my dmf from failure. its just so easy to drive lazy without changing gears after the remap
  1. Dual Mass Flywheel - OE or Not OE
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2010, 01:30 PM
  2. Need advice - broken dual mass flywheel
    By raveyd in forum Touran - Sharan - Caravelle
    Last Post: 21-02-2010, 11:43 PM
  3. Please Help Is this the correct flywheel and clutch for a 92 2.4D T4?
    By IanNorway in forum The Commercial Range
    Last Post: 21-11-2009, 11:57 PM
  4. clutch replacement needs new dual mass flywheel???
    By mrobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2008, 10:56 AM
  5. flywheel wanted for a 1998 a3 tdi
    By umran9 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 23-05-2008, 06:20 PM
