Thread: Engine Codes
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Engine Codes
    DSG4ME Guest
    Which engine is the dog one and how do you tell if it's in the car?
    Better explain better, this BKP etc code for the type of engine, what I'd like to know is which one is the bad one and were the later ones any better, and also where to look to find which engine is fitted to any particular car.
    thx in advance.
  2. Re: Engine Codes
    Feb 2010
    Louth Ireland....
    On the drivers side door pillar i think the kw rating and engine type are there ?
    If not check the vin plate under the bonnet. I'll have a look later, dont have the passat with me today......
    Ex Passat B6 owner......to many retrofits to mention !
  3. Re: Engine Codes
    Nov 2008
    Lincoln, UK
    Passenger side B pillar. Mine has BKP code written vertically. Nothing on the VIN.
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  4. Re: Engine Codes
    Dec 2009
    14 Post(s)
    Quote Originally Posted by dunkley201 View Post
    Mine is a BKP. Is that bad?
  5. Re: Engine Codes
    Nov 2008
    Lincoln, UK
    Quote Originally Posted by rapport25 View Post
    Search on here. BKP is the code all the negative posts have been about. 05/06 ones worst I believe (oil pump failures). 07 a little better but still has the expensive injectors. Mine is 07.
  6. Re: Engine Codes
    Dec 2009
    14 Post(s)
    Great!!!!! Long life servicing is a real no no if . I think I will be changing my oil at 10k also using engine flush as it may help the pump last a bit longer!!!!.
  7. Re: Engine Codes
    DSG4ME Guest
    I'm looking to do that myself if I get one, I believe the one I'm negotiating on at this time is on set servicing already, personally I don't gig this long life bull, it's purely there for fleet managers to save Ł150 per unit over the time they lease it, oil is oil regardless when it comes to contaminates, and these build on every cycle of the engine, some oil stays on the bore wall during combustion, then along comes the scrapper ring to pull the carbonised residue back into the sump with the rest of the oil, only my personal opinion though so don't take it as law, I'd also recommend inj cleaner in the tank every 20k to help keep the squirter's pattern clean, but use a good quality one not some stuff on Tesco's shelf for Ł2.99, I use Fortrun ones myself, VAG has issues about cleaners, when I bought the Skoda I was told not to use either fuel or engine cleaner in it, I heed the engine one due to the potential sludge to oil feed issue, but the tank one I use without any problems, I wonder if VAG prefer you to get gunked up so they can have access to your wallet fixing things that have blocked up.
    Does anyone have the full engine code list available and the time period the engine was likely to have been fitted? you can't trust the dealers tbh, I've seen an 09 CR Sport, but I'm 50/50 as to if it really is a CR, the car has the newer radio unit in it, but the performance figures they list don't tally to a CR or a PD for that matter
  8. Re: Engine Codes
    Nov 2008
    Lincoln, UK
    Quote Originally Posted by DSG4ME View Post
    I am sure PDs gave way to CRs by mid/late 08. An 09 is certainly a CR.
  9. Re: Engine Codes
    DSG4ME Guest
    Not always, there is the old stock thing, I once had a mate who had an R reg Pug 405, as the 406 came about on an N plate it made his look like something was amiss, but it turned out it was a Pug internal car and they simply hadn't registered it until 1997, the radio unit in the VW would hopefully suggest a CR as the car is new spec, just a shame they deleted the Sport for what I can only describe as a chavved out mess R Line, horrid seats, no rear electric windows and a body kit that just looks stupid imo.
  10. Re: Engine Codes
    Nov 2008
    Lincoln, UK
    You are right, however nowadays there is so much pressure on dealers to achieve sales targets you are more likely to see "pre reg" dealer stock cars rather than a late reg as you described. Re the passing of the Sport - it looks like the VW answer is really the CC, not the R Line. That looks as if it is just a chavved 'S' - maybe as the S's never did fly off the shelves.
  1. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  4. Engine Codes
    By t0m541 in forum Audi A3 - Archive Topics
    Last Post: 27-09-2007, 10:45 PM
  5. Newbie - first post- looking to buy!
