Thread: Passat 2.0 TFSI Loss of power???
Results 1 to 10 of 11
  1. Passat 2.0 TFSI Loss of power???
    Apr 2009
    Hi Guys,need some help my passat isn't picking like it did yesterday. This morning I started it and heard a funny mechanical sound. While driving home from work I noticed the car wasn't flinging me down the road like it normally does. It's just hit 70k and last service was from VW. I was thinking it's maybe turbo pipe has anyone had these prob's themselves?
  2. Re: Passat 2.0 TFSI Loss of power???
    Norfolk
    Sounds like loss of turbo pressure but you need a fault code read to point you in the right direction.
  3. Re: Passat 2.0 TFSI Loss of power???
    Apr 2009
    Went garage to have it checked and it started working fine??? back home it's playing up again??? While driving it everything was fine again for 1 day the next day I was getting the problem again with no turbo kick. I haven't had it on the diagnostic yet hopefully will this week. I was wondering if anyone with a tfsi has had this problem. Thanks
  4. Re: Passat 2.0 TFSI Loss of power???
    DSG4ME Guest
    Check any pipes that run along the bulkhead, and go to the airbox.
  5. Re: Passat 2.0 TFSI Loss of power???
    Apr 2009
    Hi, I've had the car on the diagnostic machine. It points to a lean burn which mechanic thinks could be Mass Air Flow sensor??? do you think its this or EGR valve???
  6. Re: Passat 2.0 TFSI Loss of power???
    DSG4ME Guest
    MAF throws on the EML and cuts out the turbo if thats any help.
  7. Re: Passat 2.0 TFSI Loss of power???
    Apr 2009
    Hi Just thought I'd update you guys. Car went to local garage who I normally use, he couldn't sort problem so car is now with VW who told me it's MAF sensor which it wasn't so had to take back. They have had it all day and gone through the possible 5 parts they had listed in their manual. Still not sorted. They are now speaking to VW to get futher help...
  8. Re: Passat 2.0 TFSI Loss of power???
    Apr 2009
    Car going back to VW for 3rd time tomorrow. So far I have had MAF Sensor, PCV Valve - These were changed by local garage then when with VW they said it was lamda sensor again no change power still low... I'm getting frustrated now - Of all people VW should know what to do??? Can any one help with this???
  9. Re: Passat 2.0 TFSI Loss of power???
    Southern County Softy
    20 Post(s)
    A full scan would help, post it here for people to see.
    A4 2.5 tdi QS (mapped)
  10. Re: Passat 2.0 TFSI Loss of power???
    Apr 2009
    The fault code is P2177 and VW have gave me car back saying they can't fix. So far I have spent approx £750 with vw, they have changed MAF, Lambda sensor and they have resetted the throttle body,this was all referred back to their tech department. I had enough and bought the car back, they wanted more money!!! if VW can't sort this out then it goes to show how crap they are. I've got a lsit of numbers which I think is the fault print out but not sure which ones I should put on this page. Any help will be appreciated. Thanks
  1. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  2. Please Help Differences between Passat 2.0 TDI and other VAG 2.0 TDI engines
    By the surfer in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-03-2010, 03:18 PM
  3. Please Help Loss of Power Passat TDI - IN the Morning
    By RichardCaul in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2009, 05:18 PM
  4. 1994 Passat 2.0 16v - Lack of power
    By oldboy in forum Early Passat Forum - Pre 97
    Last Post: 12-12-2007, 07:02 PM
  5. Passat Power loss, not the maf
    By Andyrg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-12-2007, 11:51 PM
