Thread: Location of the IAT (G42) and Boost Sensor (G31) Sensor
  1. Location of the IAT (G42) and Boost Sensor (G31) Sensor
    Mar 2010
    Cape Town, SA
    On my 2.0TDI (PD140 BLB) Engine,
    Where can I find the Intake Air Temperature Sensor (or is it just another name for the MAF/MAS by airbox)
    and the Boost Sensor (or is it another name for the MAP/Thrust Sensor by intercooler)
    18000/P1592/005522 - Altitude Sensor / Boost Pressure Sensor: Implausible Correlation
    16497/P0113 - Intake Air Temperature (IAT) Sensor 1 Circuit (G42): High Input
    Thank you
  2. Re: Location of the IAT (G42) and Boost Sensor (G31) Sensor
    Feb 2010
    basingstoke
    Air intake sensor is part of the airflow meter
    Boost sensor is normally in an intercooler pipe on the high pressure side of the turbo
    To be honest if you change the air flow meter you will prob find the boost sensor fault will go as the air flow will affect the boost
  3. Re: Location of the IAT (G42) and Boost Sensor (G31) Sensor
    Mar 2010
    Cape Town, SA
    Thanks,
    A mate just showed me on Elsawin that the g31 and g42 is the same sensor on the 2.0TDI BLB engine, which is the MAP/Thrust Sensor at the intercooler.
  4. Re: Location of the IAT (G42) and Boost Sensor (G31) Sensor
    130 Post(s)
    1972 Post(s)
    The thrust sensor (combined MAP/IAT) is on the intercooler under the left headlight, part number 038 906 051 C, Bosch 0 281 002 401
  1. Misfiring Vw Golf Mk4 Help!
    By golf vw 4 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-12-2012, 05:29 PM
