Thread: Rear Brake Caliper Rebuild
  1. Rear Brake Caliper Rebuild
    Oct 2009
    Worthing
    Mr MOT tester has identified a leaking rear caliper. Anyone rebuilt one? I'm assuming I can get a kit to do it from VW/TPS? Can I do it myself or are special tools needed?
    JAmes.
  2. Re: Rear Brake Caliper Rebuild
    Norfolk
    Unless you are pretty good at this I would buy a new caliper. Get one from eurocar spars or GSF. It will be a recon exchange, but it will have been tested. A lot safer.
  3. Re: Rear Brake Caliper Rebuild
    Jun 2006
    UK, Mids
    I replaced the rubber seal in one of mine because I had two new ones which came with the dust boots I bought, I didn't bother with the other side.
    The dust boot was ripped and I went to the dealer for a new one, but the dustboots only came in pairs with new seals too and some red lubricant you had to soak the new seal in first for 4 hours. The kit was rather expensive and hard to fit (get piston back into calliper with seal bulging) but not impossible.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Rear Brake Caliper Rebuild
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I don't think you can get a build kit these days. I would buy a VW re-manufactured caliper ( exchange for your old unit ) . They may be a little dearer than other suppliers but the quality is guaranteed. the last ones I bought a few years ago were £75 ea. It is vital that re-con calipers are properly pressure tested . Many are not and the Hose fine threads/ bleed nipple threads/seating area may well be damaged . I know of only one re-manufacturer ( Swedish ) that issues a pressure test certificate with each sealed unit .
    I once tried to buy front calipers for peugeot 106 from a reputable European/UK wide spare parts co. After checking 5 calipers, couldn't find one that had undamaged hose threads . tried a few and they leaked ! How do they pressure test when you can't screw in a new hose fitting by hand because the threads are damaged ? . Looked at some other re-manufacturer's calipers and found that the hard chromed guide pins had been re-manufactured with Zinc plated items which were seized in their guide bushes !
    You will need a piston wind-back tool for rear calipers.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Rear Brake Caliper Rebuild
    Gwent
    Caliper seal kit available from here:
    http://www.biggred.co.uk/vwshop.html
    I think Passat would be the same as Golf 4? Best to check with them.
    Other option for new calipers is:
    http://sites.internet.lu/folders/cus...RS2.htm#BRAKES
    They are offering the modern alloy caliper as an upgrade for retrofitting to old audi's, which use a full cast steel caliper with a more vulnerable handbrake mechanism
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  6. Re: Rear Brake Caliper Rebuild
    Oct 2009
    Worthing
    Thanks for the help guys.
    I've decided that I'll just buy a new caliper as its only twice the price of a rebuild kit and less than half the hassle.
    JAmes.
  7. Re: Rear Brake Caliper Rebuild
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Quote Originally Posted by jammy86 View Post
    JAmes.
    Good choice
  1. Brake Light Conundrum?
    By Eags in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2010, 11:17 PM
  2. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  3. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  4. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  5. A4 Front Brake Pads
    By mrp727 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 06:42 PM
