Thread: front crankshaft oil seal
Results 1 to 9 of 9
  1. front crankshaft oil seal
    Aug 2008
    hi everyone
    just wondering if anyone has had experience of replacing the front crankshaft oil seal. my is a 1.8t 1999 (engine code AEB) i.m just in the throws of doing the cam belt/water pump etc and have noticed lots of oil around the crankshaft area!!
    seems a safe bet its coming from the crankshaft seal, is it easy to get the old seal out and the new one in?
    cheers............. mark
  2. Re: front crankshaft oil seal
    Oct 2009
    Worthing
    I've got a similar issue. Somone told me not to bother changing the seal as they are meant to be quite expensive. Got no idea if its true though.
    JAmes.
  3. Re: front crankshaft oil seal
    Aug 2008
    Hi james
    pick up an oil seal from GSF car parts today only £5.50. just hope the old one comes out easily!!!
    cheers ............. mark
  4. Re: front crankshaft oil seal
    Oct 2009
    Worthing
    The guy I spoke to seemed to think the seal was on some plate thing that made it hard/expensive to change but as I said he might have been talking BS.
    Let me know how you get on as I need to sort mine too! and will be super happy if its not too difficult.
    JAmes.
  5. Re: front crankshaft oil seal
    Aug 2008
    hi james
    just a bit of an update, yes the seal is housed in a removable plate which is easily removed (3 x M6 capheads and 3 x M6 hex bolts) the seal is then very easy to remove and refit. the plate is sealed using liquid gasket compound.
    a nice cheap and easy job to do when you're changing that cambelt
    i have spec/dimension for holding tool you'll need to get the timing pulley retaining bolt if you need it. if you can not get a holding tool made you can have the one i made!!!
    cheers................ mark
  6. Re: front crankshaft oil seal
    Quote Originally Posted by markgrff17 View Post
    hi everyone
    I would suggest the oil leak was due to pressure being developed inside the crankcase due to your breather problems. Have you inspected the oil strainer/pickup, breather problems can cause blockages here also.
  7. Re: front crankshaft oil seal
    Aug 2008
    hi
    no i've not inspected the pick up strainer, do i need to drop the sump off to see the strainer?
    cheers............ mark
  8. Re: front crankshaft oil seal
    Oct 2009
    Worthing
    Cheers for the info mark
    The info on the tool would be super! Can you PM it?
    JAmes.
  9. Re: front crankshaft oil seal
    Aug 2008
    hi james
    yes i'll pm you the dimensions but if you need one sharpish i'll send you this one!!
    cheers ........... mark
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. How does the Quattro system work?
