Thread: ECU failure
Results 1 to 10 of 13
  1. ECU failure
    Not sure if I posted the problem with my glow plug warning light before? Anyway, intermittently my car (140 TDi Sport 06 96k) won't start (turns over but does not fire) glow plug warning light flashes and advises garage trip. Leave for ten minutes it then starts but the glow plug light flashes continously. Leave overnight problem dissapears. Finally got round to taking it to The ******** and they advised ECU failure about £1k to replace . Good news covered by warranty .
    They also suggested replacing the brake fluid every 2 years? I declined
    and about £100 to fix an airbag fault caused by connection under the seat whis seems to be a common problem .
    Glad I bought that warranty and for once a good news story re warranty companies.
    Also been driving a Vauxhall Insignia for the last few days - a nice car - but looking forward to getting the passat back
  2. Re: ECU failure
    Mansfield, UK
    ECU failure is very rare and I'd be very surprised if it is that and not repairable.
    Also, brake fluid change at 2 years is definitely required - brake fluid absorbs water and gets less efficient from the moment it is put in. You really, really should have it changed as advised.
  3. Re: ECU failure
    Apr 2007
    France
    12 Post(s)
    Ask them to test the brake fluid.
    Mine's three years old, and at the last service it was tested and found to be ok - it will however be changed next service.
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: ECU failure
    130 Post(s)
    1972 Post(s)
    I have just replaced the ECU on an Altea with an EDC16 ECU which is what I think yours will have. These are developing a reputation for failure where they loose an earth feed internally which causes an ECU relay triggering and glow plug control problem. They cannot be tested or repaired, you have to use your judgement and hope you are right.
  5. Re: ECU failure
    Mar 2009
    York
    i can help you with at least one problem - the airbag connection under the seat... this also happened to me when the airbag warning light came on, and I found the connection under the passenger seat to have been disconnected. With the battery off, I reconnected the two wires (a simple clip), and all was well, though the airbag warning light was still on (meaning the whole system is disabled). A quick trip to an independent, and a free VAG-COM clear code later, and all was well.
    Moral of the story? Don't trust the dealer - get an independent to look at it - my independent said they would also have reconnected it for me, free of charge - they do like to prove the unnecessarily high dealership costs are just ripping us off...
    ps: at the same time they also tried to tell me the fault would only be cured by a whole new passenger airbag, cost £450... never told me about a loose connection under the seat!!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  6. Re: ECU failure
    Rutland
    Quote Originally Posted by shark_90 View Post
    ABS pump failure due to internal rusting caused by water absorbed by brake fluid is not unknown. Replacement is expensive and there will be no contribution from VW if the fluid has not been changed according to schedule.
    I notice the schedule now seems to be after first three years and then every two years rather than every two years as it has been for as long as I can remember.
    Passat Estate GT 16 190/295 DSG Sand Gold/Espresso, Premium LEDs, Area View, DA Pack Plus, Park Assist, XDS, Boot divider, Olive Ash.
    TDI history, all saloons: CC 59 140/236 GT, Passat 06 140/236 Sport, A6 SE 2000 110/173, A4 SE 1995 90/149, 80 1992 90/134, plus SWMBO's 2000 A3 SE 90/155 hatch.
    1979 Alfasud 4 door 1.5 in Verde Pino. 105 bhp Green Cloverleaf engine .
  7. Re: ECU failure
    Thanks to All.
    I'll get the brake fluid done by the Indy I use - rather he had the money.
    The warranty company insisted I go to a national auto centre first. they said there was nothing they could do - according to their techie the RAM in the ECU was 'knackered' and it needed to go into VW. So I'm fairly confident it has gone and I'm sure the warranty company must be sure to (just glad I'm not paying for it).
    Wish I'd posted earlier as the airbag fault was fixed today DOH!
    Pezz
  8. Re: ECU failure
    130 Post(s)
    1972 Post(s)
    I haven’t noticed the schedule change to three years, I will look into that.
  9. Re: ECU failure
    Rutland
    Crasher, FYI I got that from the Service Schedule booklet for my CC which is Art.-Nr.:102.5R3.PKW.20; Print status 19.08.2009, Englisch 11.2009. The booklet applies to most current VW passenger vehicles.
    Other things have changed as well. I particularly noticed cam belt change interval for four cylinder TDI PD engines is up to 100k. The same interval is specified for all four cylinder TDI engines with factory fitted DPF. However there is also a 140k interval for 1.2, 1.6 & 2.0 litre common rail engines. I understand all 2.0 litre common rail engines have a factory fitted DPF so 100k as above seems appropriate?
    Also no mention at all of any time limit for cam belt changes.
  10. Re: ECU failure
    Jan 2010
    Wombourne, UK
    Hi Pezza, which warranty company do you have your policy with? I've had both problems that you have mentioned - airbag fixed under warranty, but ECU was out of warranty and cost £900 to fix. Did not take out extended warranty as feedback was they don't cover electrical faults, which your policy does.
  1. Please Help 1997 1.8T - Engine ECU Failure
    By amirs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-04-2009, 08:43 AM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Touran 2.0TDi ECU failure?
    By dleh in forum Touran - Sharan - Caravelle
    Last Post: 19-01-2008, 12:10 PM
  4. Replacement ECU
    By brendanm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2007, 02:12 PM
  5. Possible ecu failure? V6 30v 2.8
    By JodyV6 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2007, 04:47 PM
