Thread: t5 interior lights not working
Results 1 to 10 of 11
  1. t5 interior lights not working
    Sep 2008
    hi can anybody help still have no lights bulbs fine all fuses checked and fine but stuck now any suggestions welcome.... please email me bettinson@blueyonder.co.uk.
  2. Re: t5 interior lights not working
    What type of vehicle and what year?
  3. Re: t5 interior lights not working
    Sep 2008
    thanks for the reply the van is a transporter 04 plate or 2004 t 28 1900cc
    it would be great if some one could point me in the right direction as it's a *** not having lights in the dark.... many thanks to all that helps regards mark...
  4. Re: t5 interior lights not working
    The light is controlled through the onboard supply control unit,so the first thing you need to check is if the light has power,remove the lamp and check if you have power on the red on black wire
  5. Re: t5 interior lights not working
    Sep 2008
    Hi no power to the lights which is the supply unit the one under dash or under seat.
    thanks for help..
  6. Re: t5 interior lights not working
    It is the one under the dash,be sure the fuses are ok
  7. Re: t5 interior lights not working
    Sep 2008
    i have checked fuses fine must be power supply box under dash
  8. Re: t5 interior lights not working
    Nov 2010
    Warwick, UK
    Mark,
    did you ever find the cause of this fault? My 2007 T5 has the same problem.
    I have seen a report on another van of a poor earth under the floor mat, but haven't looked there yet
  9. Re: t5 interior lights not working
    Sep 2008
    hi yes found the problem your correct in the earth cable under floor mat that isnt the prob as that only earths the heater, there is a power control unit above the throttle approx 6inchesx 6 inches. thats the prob i replaced mine and it was sorted. cost a bit though....i thought i would be clever and buy a new one and stick it in my self i had done that and it was fine threw the old one away until my fuel was s--t i then found out i needed it coded .pity i didnt keep the old one cos they needed the info off it another 50 quid. so the thing is fine now getting 30mpg around town and the light all work.... hope this helps...
  10. Re: t5 interior lights not working
    Nov 2010
    Warwick, UK
    Thanks Mark,
    how much did it cost for a new control module?
    Just thinking whether to bypass that module and wire the lights to a timer relay instead....
    Steve
  1. Replies: 0
    Last Post: 12-12-2009, 11:08 PM
  2. Please Help Gauge's Not working
    By gtflyrob in forum Golf MK3 - 1993 - 1999
    Last Post: 16-09-2009, 10:42 AM
  3. Please Help CD Player not working / fuse location / replacement
    By Audi-heck-do-U in forum Touran - Sharan - Caravelle
    Last Post: 14-04-2009, 09:01 PM
  4. ARGHHH Dash not working!!!!!!
    By 1.9 TDI Sharan in forum Touran - Sharan - Caravelle
    Last Post: 21-12-2007, 12:11 AM
  5. Near SIde Main Beam STopped Working
    By markb1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2007, 10:21 AM
