Thread: Lowering - Bump Stops
  1. Lowering - Bump Stops
    Nov 2008
    West of Scotland
    For the first time, I'm about to fit Eibach -30mm lowering springs to a 2000, A4(B5), 2.4 saloon and need some input.
    I recently fitted Eibach -25mm to a Skoda Fabia vRS and I had to reduce the size of both front and back bump stops. What I'm wondering is, will I need to do likewise with the B5? Or, is the B5 set up quite different from the Skoda and bump stop shortening isn't an issue?
  2. Re: Lowering - Bump Stops
    Jan 2010
    Quote Originally Posted by ming View Post
    You can fit the "sport suspension" bump stops as they are shorter. Either that or cut down your existing ones depending on how usable they are.
  3. Re: Lowering - Bump Stops
    Nov 2008
    West of Scotland
    Quote Originally Posted by steVR View Post
    Thank you.
    What's involved in cutting down the existing ones?
    (A Stanley knife was all that was required to remove a piece off of the bump stops on the Fabia.)
  4. Re: Lowering - Bump Stops
    Jan 2010
    Thank you.
    Yep a sharp stanley blade will do.
  5. Re: Lowering - Bump Stops
    Nov 2008
    West of Scotland
    Thanks for the assistance.
    One more point:
    I've been in touch with Audi here in Glasgow and now know that the rear bump stop for the "sport" is 119mm long as opposed to 134mm for the "standard".
    That's straight forward. However, they are not able to tell me the length difference for the front bump stop because, apparently, this dimension isn't given on the parts list and they don't have these in stock so can't do a physical check. Do you think it would be reasonable to assume the difference at the front would be the same as the rear?
  6. Re: Lowering - Bump Stops
    I put sport spec ones in my a4 last year with a koni suspension kit (lowering 35mm) the sport spec ones are shorter but appeared to be a heavier duty /harder material
  7. Re: Lowering - Bump Stops
    just fit the new bump stops that come with the strut thats what i did when i got my jamex kit
  1. I need new bump stops (rear)
    By ihs61 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2010, 09:21 PM
  2. Please Help Lowering springs for 93 Coupe' 2.3?
    By shure in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-07-2009, 11:37 PM
  3. Please Help Lowering Springs Advice
    By clarky26 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2009, 03:11 PM
  4. Question Lowering Sorings advice
    Last Post: 10-06-2009, 12:04 PM
  5. Sharan 1.9tdi just stops!!
    By Dorneyed in forum Archive posts
    Last Post: 24-01-2008, 11:21 PM
