Thread: Recommended engine oil for 2.0T FSI?
  1. Recommended engine oil for 2.0T FSI?
    Feb 2010
    Manchester
    I'm thinking of buying a couple of 1 litre oil for top up reasons. My car is currently running on long life service and I have no idea what oil to use. According to the Audi manual I should use VW 503 00 or VW 504 00 but what grade does this equate to? Also what brand do Audi recommend or is used by the dealers?
    TIA.
  2. Re: Recommended engine oil for 2.0T FSI?
    Norwich
    I use Castrol Edge 5W-30 which is VW LongLife Spec
  3. Re: Recommended engine oil for 2.0T FSI?
    Dec 2006
    My opinion is that you should use Castrol edge, just make sure it's got the 504 00 code on the back of the bottle (507 00 for diesels, same oil though). Castrol Edge is a branding they use for various specs of oil..You need to select the one reccomended for 'Modern VW and Audi Engines'.... at the dealers they call it Longlife III ....
    Not sure if it's just propoganda but they say they design the engines around castrol oil, and VAG even print CASTROL onto the filler cap...
    There was also the older spec Longlife II oil that was replaced by the Longlife III... I don't think you can buy this branded as Castrol any longer... but as Quantum instead...
  4. Re: Recommended engine oil for 2.0T FSI?
    Apr 2009
    Hi, if possible, always use synthetic and 5w40 (Mobil1 or Castrol), I think this is what Audi said you need to use.
  5. Re: Recommended engine oil for 2.0T FSI?
    Mansfield, UK
    The correct stuff is Quantum Synta Longlife III 5w30 available from any dealer.
  6. Re: Recommended engine oil for 2.0T FSI?
    Jul 2007
    somerset
    8 Post(s)
    The synta is a semi synthetic, the one you want is in the gold coloured container and is called Quantum longlife 111 5W-30 VW 504 00/507 00 approved. I do believe its made by castrol anyway. A good price from TPS, £22 + vat for 5 ltrs.
  7. Re: Recommended engine oil for 2.0T FSI?
    Feb 2010
    Manchester
    Thanks for the replies. Phoned the dealership up a couple of days ago and they said they use Shell Helix Ultra 5w-30.
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. Identify oil leak after oil change
    By turbocharlie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-09-2009, 01:56 AM
  3. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  4. Passat service...anyone want info?
    By m4xmw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2008, 05:33 PM
  5. Answers from an oil expert...
    By oilman in forum Archive posts
    Last Post: 20-01-2008, 05:30 PM
