Thread: Weird clunking noise?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Exclamation Weird clunking noise?
    Yateley, Hampshire
    Hi other half has a 04 plate 1.4 Seat Ibiza and she said it is making a weird noise from the front of the car. Sounds like something is loose and on full lock makes a springing noise? Could this be a coil gone? Anyone any ideas and how much it could cost? Cheers!
  2. Re: Weird clunking noise?
    130 Post(s)
    1972 Post(s)
    One or both of the wishbone rear bushes has probably failed, often called the consul bushes. The other possibility is a failed anti roll bar inner bushes. The consul bushes are easy with the proper tools (I have a set to do on Monday I think) but the ARB is much more involved as simply replacing the bushes is only a temporary fix.
  3. Re: Weird clunking noise?
    Yateley, Hampshire
    Hi there! Thanks for the prompt reply! Will take a look tomorrow. You reckon it is ok for her to drive it still on short trips?
  4. Re: Weird clunking noise?
    130 Post(s)
    1972 Post(s)
    I would think so, I have seen them being driven when they have failed so badly that the centre section has completely separated from the outer and then worked its way off the hex of the wishbone and fallen off onto the road, mind you the steering was interesting. That was on an “on call” doctors Ibiza, which uses the same bushes.
  5. Re: Weird clunking noise?
    Yateley, Hampshire
    Checked it out and it is the coil spring on the drivers side.
  6. Re: Weird clunking noise?
    130 Post(s)
    1972 Post(s)
    That is becoming common too, you should fit a pair and I strongly suggest you only buy genuine springs, pattern ones often end up with odd ride heights.
  7. Re: Weird clunking noise?
    Yateley, Hampshire
    All fixed and running fine now. Thanks for the help!
  8. Re: Weird clunking noise?
    Uncanny but I was about to post a very similar enquiry re my other half's W reg 1.8 diesel Ibiza. I would have described it as more of a grumbling noise with my suspicions being a wheel bearing or a strut. I am currently "looking" at it and notiice quite a bit of slogger between the drive shaft and hub. Is this normal and if not what is the likely cause ? Thanks, Mike
  9. Re: Weird clunking noise?
    130 Post(s)
    1972 Post(s)
    Slogger!?? Do you mean backlash? If so, yes there is a lot in the CV joints. When CV joints fail, you are left in no doubt as to what is wrong, the hammering is very distinctive. Your noise could be wheel bearings or tyres.
  10. Re: Weird clunking noise?
    Jul 2007
    Cheshire, or my A6
    Crasher,
    I've noticed that the consul bushes as you have pictured are failed on the 52 reg Ibiza 1.2 (only 26k) I have just bought (fresh 12 month MOT on it too... hmm ). The wheel moves back and forth about an inch when it's up on the wheel brace, more so on the passenger side.
    I was wondering if you could enlighten me as to what the replacement procedure is and what tools I require.
    Thanks again for your continued support.
    Paul
  1. Question clunking noise when changing 1st 2nd and 3rd gears
    By Jerome75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2009, 04:00 PM
  2. Please Help Clunking noise from front left when wheel turned in to right
    By 30miles in forum Beetle 2000-
    Last Post: 17-05-2009, 03:20 PM
  3. Loud clunking noise from gearbox!!
    By Loofer in forum Bora - 1998 - 2005
    Last Post: 31-03-2008, 05:24 PM
  4. knocking clunking noise
    By snowdog2005 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2007, 09:18 PM
  5. Intemittent loud noise from radiator area
    By TBird1 in forum Passat - Archive Topics
    Last Post: 09-02-2007, 03:20 PM
