Thread: RCD 200 stuck in safe mode
  1. Question RCD 200 stuck in safe mode
    Mar 2007
    Devon
    I just bought an RCD 200 MP3 head unit off fleebay for my other halfs 2002 Golf Tdi. I managed to get it working ok but you had to enter the security code everytime you first turned the ignition on. Now I think she has pressed some wrong buttons or something because when turning the ignition on it comes with the message 'SAFE' as it used to but it now has a number 2 in the bottom left corner of the display. Where it used to come up with the '0000' for you to enter the code after about 3 or 4 secs it now does nothing. It just stays on the SAFE screen and it doesnt matter what you do press it wont do anything. Can anyone tell me if we have completely ballsed it up or if I can fix this.
    Chris
  2. Re: RCD 200 stuck in safe mode
    Try leaving the radio on for an hour before entering the code,not too sure but i think the 2 means you have attempted to enter a code twice,again not too sure but if you enter the wrong code the third time,the unit must be unlocked by the manufacture
  3. Re: RCD 200 stuck in safe mode
    Mar 2007
    Devon
    Thanks for that. It worked. I was leaving it for an hour but not leaving it powered up because I am stupid. I just need to work out how to set it up so that I dont have to put the code in every time its switched on. Any ideas?
  4. Re: RCD 200 stuck in safe mode
    May 2010
    St Albans
    Hi there
    I have the same problem; I bought a second hand rcd 200 mp3 player and when I turn the ignition off it will stay on but the second I remove the key from the barrel, it turns off. Then just as you stated, when I start the engine again I need to manually turn it on and it needs the code entered every time.
    Is there a way to turn "safe mode" off?
    Thanks in advance for any help with this.
  5. Re: RCD 200 stuck in safe mode
    May 2010
    St Albans
    Quote Originally Posted by chrisroffey View Post
    I recently added to this querey with the same problem and I think I have the answer;
    I just spoke over the phone with a VW service rep and his solution to this problem would be to have the stereo battery replaced. They have batteries to retain memory for when they are next switched on aswell as using power from the car battery. For me this makes sense as I purchased mine from a VW dismantlers therefore, the stereo was most probably sitting in storage and the battery has eventually deteriorated rendering it useless.
    I am going to have mine replaced and fingers crossed, if all goes well I will let you know if this resolves our problem!
  6. Re: RCD 200 stuck in safe mode
    never heard of such a thing as an extra battery for the stereo,the reason the unit looses the memory is that it is wrongly connected,i think there is something wrong with the permanent live wire
  7. Re: RCD 200 stuck in safe mode
    Mar 2008
    Quote Originally Posted by kenney View Post
    Agreed
    Tiguan CR140 Sport |PDC all round| RNS 510 and RSAP/Iphone Premium BT |
    To do list: RVC, MFSW, MDI, Running Boards
  1. stereo stuck in safe mode - help required
    By sister in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-10-2010, 06:27 PM
  2. Bose concert stuck on 'safe'
    By Quattros in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2010, 07:12 PM
  3. delta cc soundsystem stuck in safe mode
    By wall263 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-02-2010, 03:51 AM
  4. Symphony in Safe mode
    By A4crossy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2009, 05:37 PM
  5. VW Jetta stereo safe mode
    By Roberta in forum Vento - 1994 - 1998
    Last Post: 09-11-2007, 08:40 PM
