Thread: redex diesel ''does it work''
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
  1. redex diesel ''does it work''
    Jul 2008
    Heard alot mixed reports about the redex, some people say does more harm than good others say it gr8...
    It any good4 cleaning her out????
    injectors etc
  2. Re: redex diesel ''does it work''
    i have used redex but not in my passat so cant comment about negative effects - im currently using forte treatment at the moment as its meant to be really good when used in a double dose to aid cleaning your vane ring
    http://cgi.ebay.co.uk/NEW-FORTE-ADVA...item1e5ad43f12
  3. Re: redex diesel ''does it work''
    Jul 2008
    Quote Originally Posted by passat 130 tdi View Post
    Not sure exactly how it aids cleaning of your ring.. (oh er.) but lowers emmissions enough to get most cars through the MOT test.
    Works best if added directly to fuel filter.
  4. Re: redex diesel ''does it work''
    Aug 2009
    N.Ireland
    I have only used it about twice in my current 02 PD car, haven't really noticed any difference, but the car is running well.
    I used to use it on a 1999 TDi Passat i had a few years ago.
    The car had got really smoky under acceleration.
    But after a treatment of redex it totally cleared it, so I am convinced by it's effectiveness to that extent.
    My best recommendation for these TDi cars, is a good hard Italian tuneup every so often, keeps em nicely cleared out.
  5. Re: redex diesel ''does it work''
    Apr 2009
    I've been using it for years both the petrol and diesel versions. On almost every diesel I've used it on the improved fuel economy has paid for the redex after just the first fill up.
    Audi A4 Avant 2.0 TDi 2009
  6. Re: redex diesel ''does it work''
    Jul 2008
    thanks for the replies!
    Heard alot good reports about that forte inject cleaner.....
  7. Re: redex diesel ''does it work''
    Redditch
    I always thought Millers Diesel Sport was the additive of choice - has this been surpassed by Forte/Redex now?
  8. Re: redex diesel ''does it work''
    Jul 2008
    Quote Originally Posted by balmer View Post
    I've always used forte on my taxis - gets the emmisions down on the 406's and TDis for the MOT a treat.
  9. Re: redex diesel ''does it work''
    Millers is a mix of cleaner and cetane booster the forte is aimed purely at cleaning the whole fuel system and also post combustion elements are also cleaned supposedly ? I will be back to using millers as soon as I run off this forte as it cant be mixed millers does make the car run alot better when used regular its like using vmax but at a fraction of the cost
  10. Re: redex diesel ''does it work''
    GRAHAM.C Guest
    I use Millers also,have found it great stuff.I had a problem with sticking turbo vanes which was putting my car into limp mode.I gave it a double dose of Millers and in no time my problem was cured.I use it on a regular basis now every time that I refill as directed and the motor runs a treat.
    2001 1.9 t.d.i. 130 PD 146000 on the clock.
  1. Classy common rail diesel joins seat ibiza line-up
    Last Post: 30-04-2009, 08:35 PM
  2. Why Is Diesel More Expensive Than Petrol?
    By JayB5UK in forum Chat - Anything with wheels
    Last Post: 25-05-2008, 07:57 PM
  3. VPower Diesel
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2008, 02:46 PM
  4. Petrol into Diesel
    By Trig1903 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 18-04-2008, 04:24 PM
  5. TT does diesel...is this the devils work??
    By audidodat in forum Chat - Anything with wheels
    Last Post: 12-04-2008, 09:10 PM
