Thread: Radio Security Code
Results 1 to 9 of 9
  1. Radio Security Code
    Mar 2009
    I've had my 57 Passat for about 3 weeks. I've just realised that the security code for the radio (MFD2) did not come with the car.
    I spoke with the supplying dealer and they told me that security codes don't get shipped with cars and haven't for several years. Codes are only needed if the radio is swapped to another car - which is my plan!
    They told me to bring the car in as the car has to connect to Germany and then they can give me the code. Unfortunately I live a long way from the dealer so would have to get my local dealer to do this - for which I suppose they'll charge.
    Is the part about the code true?
    I thought they would be able to look it up using the serial number of the radio and/or the VIN.
  2. Re: Radio Security Code
    Norfolk
    Have you checked the handbook. It might be on a sticker in the handbook or service book. Dealers haven't been able to get vehicle data for years. I think that even includes radio codes.
  3. Re: Radio Security Code
    Mar 2009
    Unfortunately it's not in the handbook or service book.
  4. Re: Radio Security Code
    Mar 2008
    It says it has to go to the dealer on the VW website. However there are people on ebay who can do the job.
    Tiguan CR140 Sport |PDC all round| RNS 510 and RSAP/Iphone Premium BT |
    To do list: RVC, MFSW, MDI, Running Boards
  5. Re: Radio Security Code
    I certainly got a little card with the code on it with my 2006 model - actually, I think it was manufactured in 2005 - but not sure if this still happens.
    I don't think the code would have been in the handbook though, because the card says it shouldn't be kept in the vehicle, whereas the handbook is designed to be kept there.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  6. Re: Radio Security Code
    Mar 2008
    I got a card with my RNS510, the old unit had the code in Biro in the section 3.4 for radios.
  7. Re: Radio Security Code
    Jun 2008
    Ben Wardle at Shark Performance (www.sharkperformance.co.uk) in Mansfield can do this sort of thing, as can Eddy at Alfaman Services (www.alfamanservices.co.uk) which I think is somewhere in north London.
  8. Re: Radio Security Code
    DSG4ME Guest
    Shouldn't be a problem, iirc the radio is hard coded to the car, so in the event of a flat battery, it simply resets itself after 5 minutes.
  9. Re: Radio Security Code
    Tewkesbury, UK
    Mine came with the car, in the handbook (since been removed!!). Must admit, I thought it was standard to supply with vehicle. Did you buy from dealer or privately?
    '56 B6 Passat Estate 2.0 TDi 140 SE with leather upholstery & sports pack
  1. Saving settings before disconnecting then battery, Radio Code
    By Keithuk in forum Golf MK6 - 2009 - 2013
    Last Post: 26-08-2010, 06:23 PM
  2. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
