Thread: Can anyone help with a whirring noise on audi a4
Results 1 to 10 of 15
  1. Can anyone help with a whirring noise on audi a4
    Feb 2010
    guildford
    Hi there, i have a problem with an Audi A4 1.8T Quattro Cabriolet 2004, I read a lot of different threads with regards to Whirring noises on Audis and i have yet to find a answer to my problem which is as follows
    Whilst driving from about 30mph and on i get a whirring noise which sounds like it is coming from the front end, this happens whether im in gear or coasting in netrual clutch in or out, Air con off/on it doesnt change, but does get louder the faster you get. if you are stationary there is no whirring at all.
    Other threads point towards the wheel bearings which have all been changed, so can rule this out, tyres have been cheaked and tried a different set but made no difference.
    There is a very light vibration through the steering wheel and pedals on idle to about 1700rpm, which may not be related to the main problem.
    Also again think is un related but the heater does blow hot air in the middle vents and cold on the outside ones which does point towards a problem pump valve unit or servos
    Please can anyone HELP me it driving me mad!!!!!
  2. Re: Can anyone help with a whirring noise on audi a4
    Feb 2009
    To me mate, the way you have explained it here, it sounds as if your turbo is on its way out , i just purchase my first audi a4 130bhp the other night and mines had this noise aswell, two hours later the turbo blew.
    You can just image how i was feeling.
    Get your turbo checked mate
    Passat TDi
  3. Re: Can anyone help with a whirring noise on audi a4
    Feb 2010
    guildford
    Thanks Mate, have managed to get the car on ramp today, Mechanic said it soundsl like Diff in Gearbox, does anyone have any experience with this problem?
  4. Re: Can anyone help with a whirring noise on audi a4
    Feb 2010
    blackburn
    hi mate .... i've just had a similar noise from my 52 plate a4 130 ... had a noise when the throttle was let off ... took it to a garage in town to investigate and found it to be the turbo !!! had a recon one fitted etc ... and it goes like a new one now ..... don't wanna frighten you or owt but catch it soon ...
  5. Re: Can anyone help with a whirring noise on audi a4
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Quote Originally Posted by rupert742 View Post
    I would tend to agree with a Gearbox bearing/Diff Bearing problem from what you describe.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: Can anyone help with a whirring noise on audi a4
    Dec 2007
    I have a similar prob, it most certainly is transmission not turbo.
  7. Re: Can anyone help with a whirring noise on audi a4
    Feb 2010
    guildford
    Just an update, it turns out it is a problem with worn bearing in the diff which is part of the gearbox costing about 1k to rebuild gearbox!
    The car has only done 75k (correct mileage full Audi service history) and am unsure how common this problem is, but i feel Audi have got alot to answer for, i might expect this from a higher mileage car but this kind of mileage!!!! is a disgrace||
    i am going to write to Audi and see what they say!
  8. Re: Can anyone help with a whirring noise on audi a4
    Nov 2006
    Hi, I have just started to note exactly the same thing on my A4, definately transmisison/speed related and nothing to do with engine revs and is there no matter what gear I am in.
    Let me know what you find out as teh root cause
  9. Re: Can anyone help with a whirring noise on audi a4
    Jan 2011
    wales
    i had the same problem with my A4 TDI .PINION BEARINGS
  10. Re: Can anyone help with a whirring noise on audi a4
    Oct 2011
    Ashington uk
    Does anyone know how much ish it costs to get pinion bearing replaced? Is it one per side or just one bearing?
  1. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  2. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  3. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  4. STATESIDE DEBUT FOR AUDI ROADJET CONCEPT
    Last Post: 15-01-2006, 03:36 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
