Thread: Immobiliser Fault
Results 1 to 10 of 13
  1. Immobiliser Fault
    Feb 2010
    stornoway scotland
    My Wifes 2001 A6 Avant 1.9tdi will start for a couple of seconds and then cuts out. As i'm at work offshore at the moment i asked a mechanic friend to do a diagnostic test on it and it showed a immobiliser fault. He told my wife that he will have to phone a mate of his to find out what to do about it. So i thought i would do a bit of surfing to see if it could be reset or switched off, but this does not appear to be possibe and i thought i would ask if any of you good people on this forum have any suggestions on how to fix the fault.
    Many thanks.
  2. Lightbulb Re: Immobiliser Fault
    Apr 2009
    Ok I had a similar fault and here is what the AA man did.
    1:Lock car on key fob
    2:Unlock car on key fob
    3:Open door(get in) close door
    4:Turn ignition on and leave on for 15 mins
    5:Turn ignition off
    6:Get out of car a lock with keyfob
    7:Unlock car with KEY and get in
    8:Start car within 30 seconds
    This apparently resets the immobilizer to the key. I had been having problems for weeks, since doing this I have had no problems for 6 months.
    Audi A4 Avant 2.0 TDi 2009
    3 0 0
  3. Re: Immobiliser Fault
    Mansfield, UK
    I've never heard of that resetting the immobiliser. Sounds like an over-complicated procedure that's meant to sound impressive to me.
    The immobiliser can be removed from the ECU, some specialists around the country could do that for you. We could do it for you by post if you wanted to take the ECU out and send it to us.
    It's likely to be the ignition barrel reader coil or perhaps the instrument cluster at fault.
  4. Re: Immobiliser Fault
    Aug 2007
    Wicklow
    Nice one Shaka.
    Printed for future reference.
  5. Re: Immobiliser Fault
    May 2007
    does sound like key getting out of sync with car. Normally happens with spare key, or when fob battery low.
    I have done the same to reset mine before, except not to wait 15 mins.
  6. Re: Immobiliser Fault
    Mansfield, UK
    Quote Originally Posted by lonky View Post
    The fob battery is only for the remote, not for the immobiliser transponder. The transponder is powered by the magnetic field emitted by the reader coil.
  7. Re: Immobiliser Fault
    Feb 2010
    stornoway scotland
    Many thanks to you all for your helpfull replies which i will e-mail to my wife.
    Thanks again.
  8. Re: Immobiliser Fault
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    you can also get an immobilser fault show up if the main battery is weak and you try to start the car, I think the voltage drops low enough to mean the immobilser cuts in. May not be an issue but then again the fault could have been stored a long time back. Worth resetting all fault codes first
  9. Re: Immobiliser Fault
    Feb 2010
    stornoway scotland
    I have just phoned my wife after advising her of Shaka's suggestion via an e-mail this morning and "hey presto" the car is now alive again and my wife is happy. Fantastic.
  10. Thumbs up Re: Immobiliser Fault
    Apr 2009
    Quote Originally Posted by hebridean View Post
    Glad to be of service, I always like to try the 'NO COST' options before taking any car to a specialist.
  1. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  2. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  3. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
