Thread: vw plug connections
  1. vw plug connections
    is there an easy way to unplug the vw electrical plugs as i keep breaking them
    im guessing there is a tool the dealers use to get em apart .
  2. Re: vw plug connections
    Jan 2009
    towcester northants
    what plugs?
    if its the normal push type clips then use a small screwdriver to lever or get in behind to lever up the clip
  3. Re: vw plug connections
    Jan 2009
    Ireland
    Glad you brought this up as I've this problem too.
    The electrical connectors can be awkward to undo. Do you push the screwdriver inside the connector or do you press on the tab?
    I've tried both without success but there must be a knack to it? Or a special tool?
    2003 Passat Sport 1.9 TDI 130BHP
  4. Re: vw plug connections
    id think you need a small screwdriver like the ones a jeweller would use slip it under the tab and lever down whilst pulling on the connector.
  5. Re: vw plug connections
    Aug 2008
    I haven't broken any of the connectors (yet )
    The method I use is to stand a screw driver vertical (point down) into the little clip. Then gently twist the screw driver unitl you hear a slight click.
    Continue to hold the clip extended while twisting the connector back and forth while gently pulling it off.Attachment 7991
  1. Delivery Times
    By samiur100 in forum Golf MK6 - 2009 - 2013
    Last Post: 11-03-2010, 01:57 PM
  2. vw crafter glow plug light
    By couriers in forum New Member Introductions
    Last Post: 20-02-2010, 09:19 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. VW transmission mount
    By davidmills in forum Chat - Anything with wheels
    Last Post: 02-07-2007, 08:14 AM
  5. Passat TDI locking brakes
    By Cathyscar in forum Archive posts
    Last Post: 23-04-2007, 11:41 PM
