Thread: Do you have a dipped-beam indicator in your instrument cluster?
Results 1 to 10 of 10
  1. Do you have a dipped-beam indicator in your instrument cluster?
    Aug 2007
    Newport, Wales
    7 Post(s)
    Just a quickie..
    When i put my sidelights on, a little symbol with two green lights appears in the central part of my instrument cluster.
    When I put my dipped beam on, no symbol illuminates in the instrument cluster - is this normal for the B6?
    I seem to remember on my B7 a symbol like this appeared:
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  2. Re: Do you have a dipped-beam indicator in your instrument cluster?
    stchris356 Guest
    It's normal, no indicator for dipped beam!
  3. Re: Do you have a dipped-beam indicator in your instrument cluster?
    Tullamore, Ireland
    Same here, no indicator for dipped beam, its a bit of a pain but what can you do!!
  4. Re: Do you have a dipped-beam indicator in your instrument cluster?
    Mar 2009
    Brighton
    My 'lights on' indicator stays on regardless (sidelights or dipped). So maybe it depends on year/coding.
    Embisix
    Current: 2010 A4 2.0TDI Quattro S line Executive Saloon (Sepang Blue Pearl)
    Previous: 2004 A4 Avant 1.9 TDI Quattro Sport (Atlas Grey)
    Previous: A string of (mainly) DOHC VTEC flavoured Hondas
  5. Re: Do you have a dipped-beam indicator in your instrument cluster?
    Nov 2008
    Beds
    Why would you drive around with your sidelights on anyway?! Either headlights or no lights IMO.
    Audi A4 B6 Avant Sport 1.9TDI (SOLD)
    His: BMW 123d Coupe Auto
    Hers: Audi A4 B8 2.0TDI 143 Multitronic
  6. Re: Do you have a dipped-beam indicator in your instrument cluster?
    May 2008
    You can turn on/off the indication with VAG-COM.
  7. Re: Do you have a dipped-beam indicator in your instrument cluster?
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by Issac Hunt View Post
    Issac.. Do you mean just for the sidelights or for independent indication for the dipped beam?
    I've had a look at the instrument cluster with a torch and I can't see the silhouette of a dipped beam symbol.
    DBSK.. I know what you mean but sidelights are good for dull days (acting like DRLs) and are worth using if your commute includes short illuminated tunnels or underpasses etc... all stuff you wouldn't really want your full headlights on for, dont you think?
    Al.
    [ Past Audis:
    A6 S-Line 3.0
  8. Re: Do you have a dipped-beam indicator in your instrument cluster?
    Nov 2008
    Beds
    Quote Originally Posted by toff View Post
    Al.
    Not really, i drive with my headlights on no matter what the weather, side lights are for leaving on when parked on a busy street IMO, each to their own though.
  9. Re: Do you have a dipped-beam indicator in your instrument cluster?
    May 2008
    Al.
    Mine had an indicator that came on when sidelights and/or dipped beam was on and another seperate one for main beam.
  10. Re: Do you have a dipped-beam indicator in your instrument cluster?
    Aug 2007
    Newport, Wales
    7 Post(s)
    Quote Originally Posted by DBSK View Post
    Or the parking lights... if you don't want your battery to go flat
    It's a shame manufacturers don't build-in low current LED parking lights which can be left on all night without risk of draining the battery. I guess the newer cars do have LED sidelights?
    On the Audi stand at Goodwood last year, I read that the new RS6 is the first production car to have LED main / full beam headlights. I would have thought they would have debuted on the Merc S-Class!
    Al.
    [ Past Audis:
    A6 S-Line 3.0
  1. Poor dipped beam on an Audi A4 1999-2001 facelift h/lamp model. Any advice?
    By impster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2010, 09:41 PM
  2. Question No n/side dipped beam....not bulb.
    By mcnob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-09-2009, 01:21 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Dipped beam problem
    By Faisal in forum Bora - 1998 - 2005
    Last Post: 24-10-2007, 12:39 PM
  5. Dipped to main beam headlight problem
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-10-2007, 09:05 AM
