Thread: Disabling engine management light
Results 1 to 8 of 8
  1. Disabling engine management light
    Oct 2009
    newcastle
    Has anyone any ideas on how to do this on a 2005 mk5 Golf?
    The reason i ask is that my car is due to go back to the lease company and i know they will probably charge me for work that does not need done.
    The car has no apparent faults.
  2. Re: Disabling engine management light
    Southern County Softy
    20 Post(s)
    A fault is logged, thats why the light is on.
    Have a look in the vagcom section for a member in your area, scan the car and clear the fault.
    A4 2.5 tdi QS (mapped)
  3. Re: Disabling engine management light
    Oct 2009
    newcastle
    I would like to just turn off the light as when i get it reset at £25 a time it re-appears after a few days.
    Any ideas on turning it off or disabling it anyone please?
  4. Re: Disabling engine management light
    Pembrokeshire
    22 Post(s)
    the only way to permanently clear the fault is to fix whatever is wrong. removing the bulb really isnt an option as it wont then illuminate before the car is started.
  5. Re: Disabling engine management light
    Oct 2009
    newcastle
    i just need a short term fix.
    Is it easy to remove the bulb?
  6. Re: Disabling engine management light
    Mansfield, UK
    Quote Originally Posted by turbodiesel3268 View Post
    No, it's an LED soldered onto the board of the instrument cluster. Getting the light reset isn't the answer, that's why it keep coming back on. There is clearly a fault.
  7. Re: Disabling engine management light
    May 2008
    huddersfield
    sometimes disconnecting the battery can put the light out for a while, it depends on the fault. But it will always come back eventually.
  8. Re: Disabling engine management light
    Dec 2006
    Get the fault codes read, then fix the issue.
    Have you already had the codes read??
    Rick
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Engine Management Light A4 TDi 130
    By MikeRyan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-06-2009, 09:37 PM
  3. Engine Management light...MAF problem?
    By KevBrowne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2009, 02:56 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. A4 engine management light .help
    By piggyA4 in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 12:25 AM
