Thread: Multiple Misfires Detected
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Question Multiple Misfires Detected
    warp_speed Guest
    Hello, I was wondering if someone might have an idea in why I'm getting a multiple misfire problem in my A4 (53 plate) 3.0V6 24k miles on the clock. Fault codes as follows
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 001 - Upper Limit Exceeded - Intermittent
    16689 - Cylinder 5: Misfire Detected
    P0305 - 001 - Upper Limit Exceeded - Intermittent
    16686 - Cylinder 2: Misfire Detected
    P0302 - 001 - Upper Limit Exceeded - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 001 - Upper Limit Exceeded - Intermittent
    I recently got the car serviced at an Audi/VW specialist who comes highly recommended, anyway my ECU light flashes on now and again whenever I put my foot down, never had it before until I got my car serviced. The coil packs were replaced before by the previous owner, there's no loss of power or hesitation when the ECU light flashes. Service included a fuel filter change and fuel system clean.
    Has anyone got any ideas in what this might be?
  2. Re: Multiple Misfires Detected
    crichten Guest
    Change your HT plugs.
    If you are with the RAC/AA give them a call tell them the car is misfiring and they should be able to come do a full diag.
    But I had the same thing and it was my HT plug.
    About £24-£30 a piece.
  3. Re: Multiple Misfires Detected
    129 Post(s)
    1972 Post(s)
    After plugs have been replaced on cars with coil packs it is common for them to fail but that is four failures although not continuous which is odd. I would have six new coil packs fitted and see how it goes.
  4. Re: Multiple Misfires Detected
    warp_speed Guest
    Quote Originally Posted by crichten View Post
    HT plug, I guess you mean the coil on plug/coil packs? Is it typical for them all to go at the one time?
  5. Re: Multiple Misfires Detected
    warp_speed Guest
    Plugs have not been changed, didn't think it was worth spending £110 to get a set of spark plugs changed, when I could get the bits from Audi myself and change them.
  6. Re: Multiple Misfires Detected
    129 Post(s)
    1972 Post(s)
    Fit new plugs and coil packs then
  7. Re: Multiple Misfires Detected
    129 Post(s)
    1972 Post(s)
    What is the engine type code? I had this happen after an oil change and it turned out to be the VVT actuator on one bank but yours may not have the system so I will check.
  8. Re: Multiple Misfires Detected
    warp_speed Guest
    I think its a AER or AEH engine code, can't remember off hand but it starts with an A, 3.0V6 petrol 53 plate
  9. Re: Multiple Misfires Detected
    129 Post(s)
    1972 Post(s)
    PM me your reg number.
  10. Re: Multiple Misfires Detected
    warp_speed Guest
    Well, I changed my plugs and coils, all was fine and dandy until the same error popped up again, can't believe 5 of my new coils are duff, does anyone have any other idea in whats causing this issue, thanks
  1. Misfiring Vw Golf Mk4 Help!
    By golf vw 4 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-12-2012, 05:29 PM
  2. Multiple cylinder misfires! (Random)
    By AndrewB648 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 09:34 PM
  3. Misfiring Mk4 1.8T
    By Shleng in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 11:17 PM
  4. Audi A4 Quattro - Multiple Organ Failure
    By AlastairR in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-10-2007, 02:44 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
