Thread: ALARM and RADIO problems
  1. Thumbs down ALARM and RADIO problems
    Feb 2010
    Cardiff UK
    Hello
    New post by new forum member so please be patient!
    My A3 Sportback 1.9 Special Edition 57 plate is demonstrating two annoying habits and I suspect they are not altogether unconnected. I intend to raise with the main dealer however some opinions would be most welcome. Symptoms as follows:
    1. When starting from cold the radio cuts out as the automatic door locking kicks in (when slowing down / stopping) It then boots up again without any prompting but with the volume back at the default level.
    2. Despite having windows closed and air vents closed off the alarm has gone off over the past few evenings (and i really don't think this is due to anyone interfering with the vehicle) It may be related to the cold in some way I just don't know. I do wonder whether this indicates its a connection misbehaving?
    Other things to note. I've also now noticed that if I turn the radio off it will turn itself back on when the aurto door locking kicks in - almost a reverse of point 1.
    Thanks in anticipation!
  2. Re: ALARM and RADIO problems
    May 2007
    knee deep in clunge
    14 Post(s)
    The grease used in the ignition switch dries out and hence these faults occur because the S contact makes and breaks.Very common and a new switch is required which has the correct grease to prolong the life of the switch.
    As for the alarm i would check the last trigger via vag com in address 46 then it may indicate the tail gate micro switch.
    If you wish to, remove the tail gate trim and disconnect the switch on the lock and monitor
  1. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  2. Please Help Radio signal disappeared - Alarm going off!
    By randall977 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-05-2009, 10:35 PM
  3. Interesting information about the A4 Cabriolet Alarm
    By grahamnice in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-05-2009, 06:39 PM
  4. A4 Alarm
    By Jimbo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-12-2007, 03:33 PM
  5. POLO 98 ignition acc position
    By Hiral in forum Polo - Derby - Lupo - Fox
    Last Post: 10-09-2007, 07:45 PM
