Thread: Tyre Pressures in Audi A4 2.0 TDI SE (59 plate)
  1. Tyre Pressures in Audi A4 2.0 TDI SE (59 plate)
    Dec 2009
    Cardiff, UK
    Hi There
    Just checked my tyre pressures and from factory they were way off what the door sticker recommends!
    The options that the door jam sticker states are:
    Normal load (no more than three people travelling in the vehicle)
    30 psi front
    29 psi rear
    Full load (up to 5 people travelling in the vehicle)
    33 psi front
    36 psi rear
    My manual does not mention any tyre pressures.
    If any of you guys have this model car what tyre pressures are you running your car at?
  2. Re: Tyre Pressures in Audi A4 2.0 TDI SE (59 plate)
    Jan 2009
    Essex
    The manual is quite interesting with regards pressures as it says :
    "The tyre pressure must be adjusted according to the load the vehicle is carrying. We recommend adhering to the tyre pressure specifications for a maximum load. The tyre inflation pressures are listed on a sticker on the end face of the driver's door.
    However, if you prefer an extra-smooth ride and the vehicle is not fully loaded, you can select the tyre pressure for a normal load (no more than three people travelling in the vehicle). However, should you wish to drive with a full load you must increase the tyre pressure to the specified maximum."
    i.e. you should put them at the max load pressures unless you want "an extra-smooth ride"
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  3. Re: Tyre Pressures in Audi A4 2.0 TDI SE (59 plate)
    Dec 2009
    Cardiff, UK
    Thanks Scotty
    So is that what you have done mate? Set your tyre pressures to max load?
  4. Re: Tyre Pressures in Audi A4 2.0 TDI SE (59 plate)
    Jan 2009
    Essex
    Yep - but then I've got the adjustable suspension and it's often on Comfort
  5. Re: Tyre Pressures in Audi A4 2.0 TDI SE (59 plate)
    Dec 2009
    Cardiff, UK
    Nice feature! I'll give mine a go at the 33 psi front and 36 psi rear pressures but i'm thinking that it's normally just me in the car with not much in the boot so I may end up favouring the smoother ride setting!
    I'm guessing that the 3 psi increase in the rear settings for max load is to do with 3 people being sat in the back and the boot full of luggage?
  1. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. The new Audi Q5: Sporty and versatile
    Last Post: 19-04-2008, 02:25 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
  5. Replies: 0
    Last Post: 02-05-2005, 09:14 PM
