Thread: Tail light fuse location?
  1. Tail light fuse location?
    May 2007
    Hey Y'all -
    - if the answer to this is already on the forum, - sorry for this, - but I have searched and can't find the answer.
    My problem is offside (only) tail light out. Replaced bulb; no fix. Checked power supply to tail light cluster; all working, including the brake light on the same bulb, so I am thinking that there isn't an earth problem at the cluster. Everything on that cluster works, except the tail light.
    Next thought = fuse out. I know that there are separate fuses for the dipped headlights on each side, so maybe ........
    The fuse box cover (dash end driver's side) lists all the fuses there, but doesn't mention tail lights at all, and I have tried removing other possible associated fuses in case it is on a shared fuse and not specifically labelled on the diagram. Nope.
    There is a label on the fuse box cover which says that there are other fuses in the E-box and also the auxiliary relay bracket. I don't know where either of them are, and can't find anything on the forum to tell me.
    Can anyone help me, please?
    tvm,
    James.
  2. Re: Tail light fuse location?
    Southern County Softy
    20 Post(s)
    check the contacts in the bulbholder, they may be bent.
    A4 2.5 tdi QS (mapped)
  3. Re: Tail light fuse location?
    The tail light is controlled through the onboard power supply control unit
  4. Re: Tail light fuse location?
    May 2007
    Thanks Kite - good idea, 'cos that was actually the issue last time I had a tail light out some months ago (on the other side) - so it was the first thing I checked this time. I also checked with a multimeter directly onto the contacts, and then onto the contacts in the multi-pin connector; no power there either.
    regards,
    James.
  5. Re: Tail light fuse location?
    May 2007
    Quote Originally Posted by kenney View Post
    Wassat then? Does that mean that there isn't a fuse to look for at all?
    James
  6. Re: Tail light fuse location?
    130 Post(s)
    1972 Post(s)
    No fuse, direct feed from the onboard power supply unit. A code read is required if the fault is not a bulb or contact.
  7. Re: Tail light fuse location?
    May 2007
    Oh bo*****s! - but thank you for the information!
    Was really hoping to solve something like a tail light out without having to visit a garage........ - or buy software, or other new kit......
    Ho hum. No smiley for resigned to fate ............
    James.
  1. Please Help Dashboard Cluster issues, rev counter, oil light and speedo
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2009, 11:31 AM
  2. Windows, door remote and int Light, fuse?
    By Haggistini in forum Golf MK4 - 1999 - 2004
    Last Post: 05-11-2009, 09:47 AM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. fuse location for radiator fan on mk4 golf
    By elliotta44 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-06-2007, 07:36 AM
  5. Number plate light
    By shd01 in forum Touran - Sharan - Caravelle
    Last Post: 21-11-2006, 10:43 AM
