Thread: Electric door mirror adjustment faulty?
  1. Electric door mirror adjustment faulty?
    Peterborough
    When I adjust the left hand side door mirror the right hand door mirror also adjusts at the same time, however, when adjusting the right hand side the operation is fine. Has anyone else experienced this problem and/or found a fix?
    Kind Regards
  2. Re: Electric door mirror adjustment faulty?
    That is how they work
  3. Re: Electric door mirror adjustment faulty?
    scarborough United Kingdom
    Quote Originally Posted by illestjt View Post
    Kind Regards
    Put your mind at rest, you are quite correct.
    The dealer pointed this out to me when going over all the instrumentation in the car. 'LEFT' adjusts both left and right mirrors, whereas 'RIGHT' only adjusts the right mirror.
    Even I thought it was a piece of Teutonic Lateral Thinking
  4. Re: Electric door mirror adjustment faulty?
    South London. UK
    Quote Originally Posted by kamikaze06 View Post
    Are we talking about right hand drive cars?
    In my car, when I last did it, if the knob is in the R position both mirrors adjust simultaneously you then have to select L to adjust the passenger's mirror, separately. And that is how it worked, also, in my old MK5.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  5. Re: Electric door mirror adjustment faulty?
    Quote Originally Posted by HHGTTG View Post
    You are of course right, so I hang my head in shame. Had a stressful day yesterday and obviously lost the plot ie LEFT for Right etc. Sooooooooo, apologies to everyone
    Will engage the brain next time if I have not been banished
  6. Re: Electric door mirror adjustment faulty?
    Jan 2010
    Chobham, Surrey
    ...and if you don't like that behaviour, it is configurable in the setup menu.
  7. Re: Electric door mirror adjustment faulty?
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Quote Originally Posted by AxeMurderer View Post
    Yes that is correct. I wondered why they want to adjust both mirrors at the same time?
    I asked a question about the visual gear change and I was told it depends on the memory display which you can switch between 1 and 2. I had a quick look through the Highline functions and I saw Mirrors which you can switched from both the individual, so thats cured my mirror adjustment problem.
    I changed it to memory 2 and I shall now have to drive it to see if the visual gear change shows up.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. faulty electric hand brake on my A6
    By brakeman in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2009, 01:03 PM
  4. Faulty central locking & electric window
    By vwcd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2007, 10:52 PM
  5. Faulty Electric Windows
    By mclean1979 in forum Polo - Derby - Lupo - Fox
    Last Post: 03-07-2007, 06:28 PM
