Thread: Which Engine Oil (1.6 TDI)..
Results 1 to 8 of 8
  1. Which Engine Oil (1.6 TDI)..
    Southend
    Hi... Am unsure which sort of engine oil I should buy for my 1.6TDI... On the cap it says it recommends Castrol, but don't know what type.. what does anyone else use? I'm quite low so need to buy some ASAP!
    thanks
  2. Re: Which Engine Oil (1.6 TDI)..
    Sep 2009
    Tamworth
    You will need longlife oil because it has a DPF
  3. Re: Which Engine Oil (1.6 TDI)..
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Yes they gave me a litre for topping up this week, Castrol 5w/30. I believe its not cheap at Ł18 a litre.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: Which Engine Oil (1.6 TDI)..
    Apr 2009
    Suppose I should really check the oil in mine too. I'll most likely check with my local garage what to put in it just in case...
    Arrived on 29th September: MK6 Golf Bluemotion SE - Reflex Silver
  5. Re: Which Engine Oil (1.6 TDI)..
    Sep 2009
    Tamworth
    Longlife top up oil from the local dealer near me it's about Ł15 for a litre
  6. Re: Which Engine Oil (1.6 TDI)..
    Sep 2009
    12 Post(s)
    Quote Originally Posted by johnnny View Post
    Yes I don't know the actual price I was talking to one of the guys at work who has a Golf and he had to buy some from an Audi dealer last year and it was Ł18 a litre.
  7. Re: Which Engine Oil (1.6 TDI)..
    May 2006
    Redruth, United Kingdom
    If you have a DPF fitted then you will need an oil that meets the VW507.00 spec and these are 5w-30.
    All of these are approved http://www.opieoils.co.uk/c-754-vw-50700-oil.aspx
    Guy
  8. Re: Which Engine Oil (1.6 TDI)..
    Sep 2009
    United Kingdom
    Halfords have 5 litres of Mobil 1 ESP 5W30 Fully Synthetic Engine Oil
    on offer for Ł39.99 thats only Ł8 per litre - seems a very good deal
  1. Replies: 0
    Last Post: 23-01-2010, 07:00 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  4. '92 MkII 1.8 NO oil pressure
    By 2old2turbo in forum Golf MK2 - 1984 - 1992
    Last Post: 06-10-2007, 09:58 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
