Thread: Mk4 golf tailgate lock problem
Results 1 to 10 of 14
  1. Mk4 golf tailgate lock problem
    sandancer Guest
    Hi, After resolving my electric window & door central locking problem (blown fuse) the tailgate lock does not work from the remote. I've removed the interior cover to inspect, the barrel locking mechanism works fine and the solenoid manually moves. Could the problem be related to the soleniod or the sensor which I think detects that the tailgate is fully locked?
    I tried to check if I am getting a feed to the soleniod whilst the tailgate is closed, but only on occasions I get a feed, and this only seems to happen after I have armed the remote locking then manually open the tailgate.
    Sorry its abit long winded, but the more info the more someone may undertsand.
    Apr 2007
    Repulik Of Mancunia
    I'd like to know this, my Mk4 does the same, boot doesn't work on the Central locking, you have to open it manually. very annoying. There isn't even a boot catch inside for it.
    '99 Golf GT-TDI
    MUFC - One Love
    Good Rep Always Appreciated.
    May 2007
    I have an interresting tailgate problem too, which might shed some light.
    First - the whole lock system seems quite complicated and I'm far from sussing it all out!
    I have never had a boot light. Bulb is fine. Read some stuff on UKMKIVs adn Vortex but little of great help.
    Have bought a new VW part "micro switch" for boot lock, but can't see where to fit it. If i plug it in to the loose connector (car had had boot damage prior to me owning it - so reckon the 'repairers' didn't bother refitting/buying a new one) to the right of the lock system and press the micro switch the interior lights come on - so i'm guessing it now thinks boot it open. Reckon it goes some where near the actual boot catch mechanism that I can't get at til i get the correct spline tool.
    However - still no boot light!
    I think this is a microswitch in the catch mechanism (has a little 3ping connector plug to harness) that's corroded - sure looks it.
    Do you really have no boot catch to hold the boot shut or do I misunderstand??
    Does you boot light work?
    Does the alarm re-arm after about 30s if you unlock remotely and just open the boot?
    Hope to be of help and will post more as I learn it! Any help anyone can be with my probs - greatly appreciated!
    Toby.
    sandancer Guest
    Yes there is a boot catch and a switch fitted (which is located inside the tailgate and fitted directly on the catch).
    Yes the boot light does work, which is something that will tell me if the switch works (if it goes out once the tailgate is closed).
    No the alarm does not re-arm. What I mean is
    1. arm the alarm.
    2. wait a few seconds
    3. open the tailgate using the key/lock
    4. the alarm then sounds
    5. close the tailgate and ocassionally get a 12v ish feed, but no mechanical movement.
    I'm now thinking that the soleniod could be goosed, does anyone know if they are common failures?
    Hope you have some luck solving your problem.
    neileg Guest
    90% of electrical problems with tailgates on any make or model are down to the wiring harness where it joins the body to the tailgate. Over time the constant flexing wears or fatigues the wiring and you get shorts or open circuits as the wires move around.
    The additional issue on the Golf (I think this applies to the MkIV) is that the washer tube that passes through the wiper spindle leaks and you get a constant bath for the lock mecanism.
    Dec 2006
    Manchester
    Quote Originally Posted by sandancer View Post
    A friend of mine had what sounds like a similar problem. If the rest of the cars central locking worked after replacing the fuse, it's likely that the boot lock caused it to short in the first place.....
    Secondly, golf iv's are renound for the rear washer hose coming away from the jet itself and getting water all over the lock / solenoid, (this may of been what caused the short) If it wasn't the washer pipe (ie if that still works) the seals around the boot may be letting water in.
    From what you've said i'd replace the solenoid and hopefully that should resolve the problem.
    All the best...
    Nick
    May 2007
    Scotland
    Is the key hole at a jaunty angle?
    sandancer Guest
    The key hole is positioned at the 12 o'clock position. I am going to have another look over the week end to try and bottom this out!
    Watch this space!!!
    sandancer Guest
    Well, after an hours investigation, I've managed to find the route cause of my problem (see attached picture). Well as 'neileg' mentioned 90% of electrical faults are related to the wiring harness. I'm sure many people have come across this before, but could you let me know what was done to repair this and has it lasted long, also an approx cost. Can a samll part of the harness be replaced?
    My short term solution was to crimp the broken ends together, as I thought soldering would just make the copper more brittle and fracture again.
    Many thanks for everyone's help.
    neileg Guest
    Just crimping the ends toether won't be a long term cure. The fatigue in the wires will be nearly as bad within a centimetre or so of the break. So it will go again.
    You really need to cut back about 100mm on each side and replace with new wire. Soldering or crimping wil be fine. You need to use new wire as this the plastic sleeve will be more fleixble than old salvaged wire. A bit fiddly but not that hard and not expensive. Expect the repair to last at least as long as the age of the car now.
    Last time I had to do a splice repair like this it was under the bonnet, in the rain, on the Edinburgh ring road. Stressed? You bet!
  1. Passat Estate tailgate lock
    By waylonbuddy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2007, 12:21 AM
  2. Passat Estate Tailgate Problem
    By willy100 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2007, 09:23 PM
  3. Golg MK IV Tailgate central locking problem
    By chetc in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 07:11 PM
  4. 96 passat boot tailgate lock
    By dyson in forum Passat - Archive Topics
    Last Post: 01-01-2007, 11:34 PM
  5. Tailgate doesn't lock (1.8T sport estate)
    By davegwynn in forum Passat - Archive Topics
    Last Post: 17-02-2006, 01:41 PM
