Thread: fault code 02000
  1. fault code 02000
    Sep 2008
    Hi ive got an a4 cab sport and this fault code has appered. I can open the roof only about 3" and it stops and this code comes up. I recently have replaced the rear storage unit and the top lock switch. Will i have to do a manual reset now for it to work?
    Hope someone can help, many thanks.
    Brian
  2. Smile Re: fault code 02000
    Dec 2007
    02000 - Switch Position
    02000 - Switch Position: Implausible Signal
    Possible Symptoms
    • Automatic Roof not working
    Possible Causes
    • Automatic Roof Switch Positions implausible
      • Micro Switch faulty
    Possible Solutions
    • Check Micro Switches
      • Check Measuring Value Blocks (MVB)
    Special Notes
    Adaptation
    Channel 01: Reset
    Prerequisites:
    • Automatic Roof closed
    • Measuring Value Blocks (MVB) OK
    To reset the switch positions, save a new value of 1.
    Special Notes
    • If Adaptation will not set with only the 02000 fault present, check TSB 61-08-05 (2010940, NAR only)
  3. Re: fault code 02000
    Sep 2008
    Hi its say implausible signal, i dont have a vag com used a friends garage computer to get this code and reset it. anything else I can do?
  4. Re: fault code 02000
    Nov 2008
    Leeming
    Once you have reset the switch positions via vagcom, open the roof manually all the way back to fully closed and then put the roof back up
    This will tell the ECU the correct values for all the switches when it opens and closes
    If you dont know how to undo manually have a look on the right handside of your dashboard there is a key next to the fusebox, this will undo the roof at the front, there is also a keyhole between your backseats on the underside which opens the back panel
    its best if you have 2 people as the roof is heavy and somebody needs to lift the back panel aswell as holding the roof !!
    Good luck
  5. Re: fault code 02000
    Sep 2008
    Thanks Blackpool, do i have the ignition on or off for the manual reset?
  6. Re: fault code 02000
    Nov 2008
    Leeming
    ooh, you got me there.
    Can't remember what I did, I would say key in ignition but not started
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. Code Fault Recognition
    By csducks in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-01-2010, 10:10 PM
  3. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  4. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
  5. Please Help Climatronic Fault Code.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2009, 04:49 PM
