Thread: Leaking Windscreen Washer Bottle
  1. Leaking Windscreen Washer Bottle
    Feb 2009
    Morning,
    I've read the previous posts on this subject but none appear to really answer my question below:
    Can anyone help as my washer bottle seems to be leaking, it empties very quickly and the warning light comes on. Is it possible to get to the bottle from the top or do you have to go under the car if a tube has become disconnected ? I can see water dripping underneath the engine, wondering if going through fairly deep snow could have "pulled" the hose from the bottle????
    Thanks in advance.
  2. Re: Leaking Windscreen Washer Bottle
    Nov 2008
    Have you checked the pipes that are onside the bonnet- that connect to the washer jets. I had the same problem and it turned out that the pipes had become disconnected because of the frost and the water was frozen in them when i tried to use them. Just reconnected them and they worked.
    Volkswagen Passat Sport 2.0 115bhp
  3. Re: Leaking Windscreen Washer Bottle
    Feb 2009
    Thanks for the reply, I've checked the hose and it all seems ok under the bonnet. The front and back washers are not working which leads me to the conclusion that the tube has become disconnected where it comes out of the resevoir. Can't get to it from the top so assume it needs to go on a ramp and the sump guard will need to come off. Does this seem feasible ?
  4. Re: Leaking Windscreen Washer Bottle
    Nov 2008
    I think so although i dont know too much about cars lol. Not too sure about this but you may be able to get at it if you remove the wheel arch liner?
  5. Re: Leaking Windscreen Washer Bottle
    May 2009
    Hungerford, Berkshire
    Hello. I had the same thing after Xmas, its more likely a pump fitting and has been pushed out because it froze. Remove the wheel, use a torx bit to undo all the liner fixings then ease this out. If its the fitting thats the problem ( lower part of the reservoir in front of you) then push this togather so the bayonet fixing home. Thats it! Use plenty of screen wash to prevent freezing. Took about about an hour.
    James
  1. Please Help Windscreen washer losing water
    By chrisop in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-01-2010, 09:27 AM
  2. Question washer fluid leaking from bootlid!!!
    By slimsladie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-01-2010, 09:10 PM
  3. Windscreen washer level warning upgrade on a TDi 170...
    By randall977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-07-2009, 07:37 PM
  4. windscreen washer bottle
    By VAG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2009, 07:01 PM
  5. Washer Bottle Problems
    By Rob58 in forum Passat - Archive Topics
    Last Post: 21-09-2007, 02:12 PM
