Thread: OEM hid light quality
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: OEM hid light quality
    Oct 2009
    Ohio
    My B5.5 had the stock halgoens when I first got it and upgrading to the OEM Xenon's was the first major change I made. I can say there is a drastic difference in light output compared to the halogen, however I don't feel they are as bright as some of the newer cars (my Mk5 R32 had better light output), I suspect because of the age / technology involved.
    Switching out the bulbs sounds like it may be a step in the right direction, I've been running the Philips 4300k and have been very happy with them.
  2. Re: OEM hid light quality
    May 2008
    Southampton
    Either will be fine as long as you get the correct fitting. Our data goes up to 2001 and lists a D2S however I would advise just checking that this is correct. Our Sister company has a few options in this size and they can be found in the following link,
    http://www.hids4u.co.uk/d2s-bulbs-c-23.html
    As you will see we don't have the Philips bulbs available but we do have 2 types of Osram bulbs and our own upgrade. The Osram Cool Blue bulbs are rated at 5000K and will give a whiter light than the stock 4100K. Our own 6000K bulbs will give an even whiter light with a slight blue tint to them. If you want more info on the colour temps please see the following link,
    http://www.hids4u.co.uk/hid-faqs-pg-1.html
    Hope this helps.
  3. Re: OEM hid light quality
    Dec 2009
    Thanks for the info guys,
    Will probably order a set of philips ones, just because I want the most light I can get and see where we go from there.
    Have vagcom as well so should be able to check and adjust the beam pattern roughly.
    2002 Passat PD 130 TDI Sport Estate
    2003 Golf GT TDI PD 130
  4. Re: OEM hid light quality
    Oct 2009
    Worthing
    Quote Originally Posted by Saturn View Post
    Pretty sure they are as they "ignite" when switched on, autolevel, and they bumper has they vw headlight washers installed behind it.
    Cool, just making sure before you go get new bulbs.
    JAmes.
  5. Re: OEM hid light quality
    Dec 2009
    Hi guys,
    just an update
    Fitted new philips 4300k bulbs and had beam pattern set by vw.
    Lights are definately brighter and better focused. However not as good as modern HID. Must be due to the technology, but am satisfied that they have at least improved.
    Thanks for your help
  1. Replies: 23
    Last Post: 20-11-2011, 06:44 PM
  2. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
  3. HID Xenon headlamp conversion kits
    By lonky in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-07-2009, 10:50 AM
  4. Headlight Conversion How To??!!
    By Paul A4 1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-04-2008, 10:57 PM
  5. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
