Thread: A6 1.9 TDi 130 oil change
  1. A6 1.9 TDi 130 oil change
    Jan 2010
    France
    Hi there,
    I am about to change the oil on my 2003 Avant. I've heard talk about longlife and fixed oil change regimes – what's the difference, how do you tell what your engine is? And should you use different oils? Do you tell by VIN number?
    Also, what's the sump nut size, and how many fixings are there to get the undertray off on the A6 - assuming that's the only realistic way to get to the sump nut!!!
    What's the oil capacity on this engine?
    Thanks in advance
  2. Re: A6 1.9 TDi 130 oil change
    Dec 2007
    London & South East
    Oil should be at least 505.01, The newest oil is 507.00 (For DPF's) (Not really necessary on the AWX engine).
    Oil filter socket required is 76mm, 14 flutes -
    http://www.halfords.com/webapp/wcs/s...egoryId_255216
    Do not use an oil filter wrench.
    Current: 2001 Audi A6 1.9 TDI PD 130 SE Avant
    Previous: 1993 Audi 80 1.9 TDI SE Avant
  3. Re: A6 1.9 TDi 130 oil change
    Pembrokeshire
    22 Post(s)
    buy a vacuum oil extractor and suck it out the dipstick tube, then suck the extra litre or so out the oil cooler under the filter.
  1. 1.9 TDi (130) Engine oil
    By Sion in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2007, 06:58 PM
  2. '92 MKII no oil pressure (0)!
    By 2old2turbo in forum Jetta MK2 - 1984 - 1992
    Last Post: 12-10-2007, 02:30 AM
  3. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
  4. Replies: 0
    Last Post: 20-07-2005, 08:45 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
