Thread: Wheels - this might be helpful
  1. Wheels - this might be helpful
    Aug 2006
    Thought that this might be of use to Sharan drivers on here ;
    Link removed
    All feedback greatfully received.
    Unauthorised links to websites will be removed - as per the forum rules
  2. Re: Wheels - this might be helpful
    Oct 2005
    Why not help the Sharan drivers on here, by posting the information here rather than linking them to what I presume is your website?
  3. Re: Wheels - this might be helpful
    Aug 2006
    VW Sharan 15 inch steel wheels, part number 7M0601027A
    If your VW Sharan, Seat Alhambra or Ford Galaxy run on 15 inch steel wheels, then they will all probably be running on the same parts.
    Both VW and Seat use the same part number 7M0601027A which refers to a steel wheel as follows - 6 JX15H2 ET55 5/112.
    The earlier vehicles, run on 15" steel rims and the later models run on 16" rims. It should be OK to fit later model rims onto the earlier models as there are many early sharans/alhambras/galaxys running around on aftermarket alloys.
    Part numbers
    Below are the original VAG part numbers ;
    Sharan/Alhambra 95 to 00, part no. 7M0601027A, size 6 JX15H2 ET55 5/112 (15")
    Sharan/Alhambra 01 to 03, part no. 7M0601027F, size 6 JX15H2 ET55 5/112 (15")
    Sharan/Alhambra 03 to 09, part no. 7M3 601 027 D, size 6 JX16H2 ET53 5x112
    (16")
    Notice above that all those sizes are 6J, this denotes a wheel 6" deep (front to back). If you have a later Sharan running on 16" wheels and you want to run wider tyres say for more grip or winter driving, you can get hold of 7J (7") wheels - the part number is 7M0 601 027 J (size 7 JX16H2 ET59 5x112).
    Other vehicles fitted with similar size wheels ;
    We are NOT saying these will definitely fit or should be, differences are highlighted in red. Bore size should be 57.1mm. Wheels with a large difference in EToffset from the originals may rub/catch the bodywork. It has been suggested that offset diferences of 5-10mm should be OK dependant on tyre sizes.
    Earlier Sharan/Alhambra on 15" wheels
    VW Passat 98>00 part no. 4B0 601 027 (size 6Jx15H2 ET45 5x112)
    VW Passat 01> part no. 3B0 601 027D (size 6Jx15H2 ET37 5x112)
    VW Passat 04> part no. 3B0 601 027 F (size 7Jx15H2 ET37 5x112)
    Audi 100 90>, part no. 443 601 025 G (size 6Jx15H2 ET45 5x112)
    Audi 100 90>, part no. 443 601 025 N (size 7Jx15H2 ET35 5x112)
    Audi 100 91>, part no. 4B0 601 027 (size 6Jx15H2 ET45 5x112)
    Audi 100 91>, part no. 4A0 601 025 K (size 7Jx15H2 ET40 5x112)
    Audi 200 85>, part no. 441 601 025 H (size 7.5Jx15H2 ET35 5x112)
    Audi 200 80>, part no. 443 601 025 G (size 6Jx15H2 ET45 5x112)
    Audi 200 89>, part no. 443 601 025 N (size 7Jx15H2 ET45 5x112)
    Audi A4 95>, part no. 4B0 601 027 (size 6Jx15H2 ET45 5x112)
    Audi A4 01>, part no. 8E0 601 027 (size 6.5Jx15H2 ET33 5x112)
    Audi A6 95> part no. 4B0 601 027 (size 6Jx15H2 ET45 5x112)
    Later Sharan/Alhambra on 16" wheels
    VW Passat 06> part no. 3C0 601 027 H (size 6.5Jx16H2 ET42 5x112)
    VW Touran 03> part no. 1K0 601 027 A (size 6.5Jx16H2 ET50 5x112)
    Skoda superb 02> part no. 8D0 601 027 A (size 6Jx16H2 ET40 5x112)
    Skoda superb 02> part no. 3B0 601 027 F (size 7Jx16H2 ET27 5x112)
    Skoda superb 09> part no. 3C0 601 027 M (size 7Jx16H2 ET45 5x112)
    Audi A3 04>, part no. 1K0 601 027 A (size 6.5Jx16H2 ET50 5x112)
    Audi A3 04>, part no. 8P0 601 027 (size 6Jx16H2 ET50 5x112)
    Audi A4 01>, part no. 8E0 601 027 D (size 7Jx16H2 ET42 5x112)
    Audi A6 99> part no. 8D0 601 027 A (size 6Jx16H2 ET40 5x112)
    Audi A8 94>04, part no. 4D0 601 025 (size 7Jx16H2 ET42 5x112)
    Seat Toledo (16"), part no. 1K0 601 027 A (size 6.5Jx16H2 ET50 5x112)
    Seat Leon (16"), part no. 1K0 601 027 A (size 6.5Jx16H2 ET50 5x112)
  4. Re: Wheels - this might be helpful
    130 Post(s)
    1972 Post(s)
    That’s for novices!
  1. Wheels
    By Mr Tibbs in forum Wheels and Tyres
    Last Post: 28-06-2009, 12:12 AM
  2. Snow Tyres/Steel wheels
    By paulm in forum Passat - Archive Topics
    Last Post: 28-11-2007, 09:22 AM
  3. Upgraded my wheels and now car feels really sketchy to drive - HELP!!!
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-11-2007, 03:59 PM
  4. How does the Quattro system work?
  5. Insurance & Modifications ££££££
    By torrox in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-05-2007, 07:39 PM
