Thread: Retro fit Parking Sensors
Results 1 to 10 of 11
  1. Retro fit Parking Sensors
    Otley West Yorks
    I am looking at fitting parking sensors on my 2006 A3 there are two good post on fitting there Audi ones at £170
    But I have come across these which seem a god idea as no drilling the bumper just installing a strip antenna across the inside of the bumper
    The whole system seems impressive here is the link
    http://www.parkingdynamics.co.uk/Veh...g-Dynamics-PD1
    But just a bit wary before I click to buy
    Has anybody fitted one of these
    And do they work accurately with no interference
    As Im just a bit concerned about the Installation part regarding the inner metal part of the bumper
  2. Re: Retro fit Parking Sensors
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Take a look at this thread.
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Retro fit Parking Sensors
    Otley West Yorks
    Thanks forinfo he seems to have fitted a cheap copy
    brian566
  4. Thumbs up Induction Loop Parking sensors
    Otley West Yorks
    Quote Originally Posted by Brian566 View Post
    brian566
    If anyody interested
    This is a comprensive installation guide on a Golf seems inpressed with kit
    C:\Documents and Settings\Brian Taylor\My Documents\My Received Files\Installing No Holes Parking Dynamics - PD1 Vision Reversing Sensor - uk-mkivs.mht
    So I think this is the one to go for due t its no holes design
    A Christmas Holiday project
  5. Re: Induction Loop Parking sensors
    May 2009
    69 Post(s)
    Hi Brian,
    Where is the guide? I can see what looks like the path to an archived web page (mhtml) on your PC's hard drive, but unless you make it available online by posting it up somewhere on the web or adding it as an attachment to this site it is unreachable by anyone except you on your PC.
    MF.
  6. Re: Induction Loop Parking sensors
    Otley West Yorks
    Sorry My mistake ! I copied to my C Drive to Print off
    here is link
    http://uk-mkivs.net/forums/t/279442.aspx
    I have spent thelast day searching all forums and only on negative comment about false alarms in rain
  7. Re: Retro fit Parking Sensors
    Mar 2007
    Oxfordshire
    I'm sure it's too late but - don't do it! I've gone down this road and they're really no where near as good as ultrasonic. When you stop the beeping stops, they are also not that accurate. Do you ever wonder why on earth car manufacturers don't use this other system? The great thing about the A3 is there is a crease in the rear bumber (and corresponding depressions in the reinforcement bar) perfect for drilling and putting in sensors. I bought 18mm sensors off eBay (which are the smallest size) and they like OEM unless you look very carefully. I took time to investigate exactly where they should be located, the result is below (sorry it's not a very clear photo).
  8. Re: Retro fit Parking Sensors
    Otley West Yorks
    Quote Originally Posted by randall977 View Post
    Thanks for your Reply
    It may not be to late as I have not installed them due to weather !!!
    And may be able to get my Money back
    Did you actually install the Ones from " Parking Dynamics "or were they one of those copies from e-bay ?
    As even f I don't receive a refund I would not want to go to the trouble of installing them as it is a bi job removing and installing the rear bumper
  9. Re: Retro fit Parking Sensors
    Mar 2007
    Oxfordshire
    No they're weren't PD1's (which I know are better quality) however it is very annoying when the beeping stops - you literally know where you are with ultrasonic. I didn't need to remove the bumper to fit my sensors - you can just about reach - just make sure you measure and mark carefully (use the reinforcement bar as a guide). The 18mm sensors aren't that easy to find on eBay - type 18mm parking sensor (something should come up). Being absolutely fair the electromagnetic sensor bar does work but only half as well as ultrasonic. Just my opinion but I think it is backed up by other peoples experiences.
  10. Re: Retro fit Parking Sensors
    Otley West Yorks
    My car is a 2006 Sportsback and i don't have the rear bumper flange line like your picture
    If mine was the same bumper i would have used the standard ones like yours as the bumpers suites them
    On the 2006 it is one big curve
    But thanks for your Info I need to think it over
  1. Replies: 10
    Last Post: 17-11-2015, 10:51 PM
  2. Question Parking Sensors - more questions
    By rwab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-08-2010, 07:48 PM
  3. Replies: 1
    Last Post: 14-12-2009, 11:49 AM
  4. Retro fit Parking sensors to 06 A3
    By zahir_213 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-04-2009, 04:10 PM
  5. Installation of Parking Sensors in 06 Passat
    By mac500 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-10-2008, 05:37 PM
