Thread: Newbie, problems with abs, esp lights 1.9TDI
Results 1 to 10 of 15
  1. Newbie, problems with abs, esp lights 1.9TDI
    Dec 2009
    whitehaven. United Kingdom
    When I insert the key into the ignition of my A4 TDIse and turn the key the abs and esp lights stay on. The engine management light and heater plug lights do not. If you turn the key to start the car it tries to fire up but will not start. If you leave the ignition in the on position for roughly 20 to 30 seconds the em light and heater plug light will kick in, the car will then start. I have had the car to an independent Audi specialist. The following codes from the VAG machine.
    2 Faults found
    18258 Powertrain Data Bus missing message from ecu p1850 -35-10 intermittent,
    1 fault found
    01314 Engine control module 49-10- No communications intermittent
    They are not sure why this is happening, Please Help
  2. Re: Newbie, problems with abs, esp lights 1.9TDI
    Jan 2009
    Birmingham
    36 Post(s)
    ask a guy called crasher he's the man on here who will know
  3. Re: Newbie, problems with abs, esp lights 1.9TDI
    Dec 2009
    How do I contact Crasher ?
  4. Re: Newbie, problems with abs, esp lights 1.9TDI
    Jan 2009
    Birmingham
    36 Post(s)
    if you go to the home screen on this site top left hand corner you will see his name click on it and send him a pm about your problem
  5. Re: Newbie, problems with abs, esp lights 1.9TDI
    Dec 2009
    darlington,england
    Quote Originally Posted by mi55gms View Post
    2 Faults found
    1 fault found
    did you find out what was causing this?
    i think i have the same fault intermittantly
    cheers
  6. Re: Newbie, problems with abs, esp lights 1.9TDI
    Dec 2005
    I have just had some problems with warning lights and my battery discharging,its taken me a long time and a lot of trouble.an indepandant garage and even the Audi garage.In the end it was water damage to some relays in the ecu box.The relays were sending strange messages,replaced them and hey presto problem solved.
    Check for water damage and corroded relays and wires.
  7. Re: Newbie, problems with abs, esp lights 1.9TDI
    Jan 2009
    Birmingham
    36 Post(s)
    check your plenum chamber cover along the top were the battery sits check if its on properly usally that couses water to get it the ecu area of the car but sounds like you got some wiring issues like the previous guy said check your wiring around the ecu for corrosion and check your relays you got some funny signals coming from your ecu usally throws up many codes
  8. Re: Newbie, problems with abs, esp lights 1.9TDI
    Jun 2008
    Beverley, east Yorkshire
    abs and esp lights is usually an indication that your brake light switch has broken or both brake lights have blown, get someone to check they are working, hope it is this as it is relatively easy and cheap to repair
    A4 AVANT 2.5TDI SPORT QUATTRO
  9. Re: Newbie, problems with abs, esp lights 1.9TDI
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Another check would be that your cars' battery is not on it's way out.
    A low battery can show signs similar due to a low voltage spike.
    Did you get hold of Crasher? I think you need to have 10 posts to use the PM function,if so re-title a new post along the lines ATTENTION CRASHER etc etc ,he WILL sort you in an instant
    Stuart
  10. Re: Newbie, problems with abs, esp lights 1.9TDI
    Dec 2009
    darlington,england
    Quote Originally Posted by fourringsrus View Post
    Stuart
    latest is the brake lights are stuck on but i dont think its the brake switch if you unplug the switch take the brake light fuse out or turn off the ignition and lock the car the lights are still on (must be a volvo) but i will try and look at it tomorrow
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. ABS and ESP light on startup
    By ddave05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2009, 11:44 PM
  3. A4 B5 2.5 Tdi Saloon - ABS system Bleeding ?
    By kevmayer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-06-2009, 05:30 PM
  4. ABS and ESP Warning Light Illuminated after Pressing Brake Pedal
    By Tub Thumper in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2008, 09:50 PM
  5. ESP off, What's the difference?
    By bquattro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-11-2007, 02:18 AM
