Thread: 18061 - Please check DTC Memory of ABS Controller
  1. 18061 - Please check DTC Memory of ABS Controller
    Hi, following code came on after the battery was disconnected. Fine before hand, cant reset it with my version of vag-com - anyone know how to reset it manually or any idea what it could actually mean ? thanks
    Steve
    Control Module Part Number: 4E0 910 560 Q
    Component and/or Version: 4.2L V8/5V G 0030
    Software Coding: 0011773
    Work Shop Code: WSC 00378
    1 Fault Found:
    P1653 - 008 - Implausible Signal
    VAG-COM Version: Release 409.1-S
  2. Re: 18061 - Please check DTC Memory of ABS Controller
    Sep 2009
    Omagh, N.Ireland
    From my own experience, you need to check the fault codes in the braking system. Mine showed the same fault code but on further inspection (vagcom scan) it turned out to be worn rear brake pads - changed pads, cleared fault codes, no more issues.
  3. Re: 18061 - Please check DTC Memory of ABS Controller
    Thanks for he headsup - something is going wrong as parking sensors have now stopped working ! Got it going into the garage thurs now - as you say needs a proper going over with VAG-COM as my version isn't showing any problems - checked all the wiring and no water/condensation anywhere so had enuff now. thanks for the advice
    Steve
  4. Re: 18061 - Please check DTC Memory of ABS Controller
    Sep 2009
    Omagh, N.Ireland
    No probs Steve, keep me updated if they find anything more serious wrong - just in case there's something I need to look out for.
    John
  5. Re: 18061 - Please check DTC Memory of ABS Controller
    so - got it fixed thanks to the guys at WVC audi - seems that it needed a reset or two and despite saying the fault was still there it now has fixed itself ! It was saying the steering angle sensor was faulty on the VAS. Still we got there in the end - nothing too drastic. thanks to those who responded
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. is there a way to check which abs sensor is faulty without vag-com?
    By tonto2k in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 25-06-2009, 01:47 PM
  3. S3 Haldex error 65535 internal control module memory error?
    By merlin2002 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-06-2009, 09:08 AM
  4. 1999 passat ABS light help
    By jonny VDUB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2008, 01:25 PM
  5. Passat 2001 1.8T - ABS Warning Light On!
    By richard child in forum Passat - Archive Topics
    Last Post: 17-01-2007, 05:38 PM
