Thread: climate control problem
Results 1 to 8 of 8
  1. climate control problem
    May 2008
    I have a B7 2006 A4 saloon with dual zone climate
    the air started to blow cool on drivers side whilst warm/hot on pass side when the temp was set to HI or warm. I looked on this site at other threads and thought it could be the motor that controls the flap behind dash, I removed the panel under the column and saw a yellow three part arm above the two heater pipes, this was hanging loose and by manually moving this i was able to make the air blow warm. there is a box the size of a matchbox with a wiring block going in to it fixed by 2 bolts, I assumed that this is the motor and the arm should be connected to this, the end of the yellow arm looks as though it has sheared at the point where it fixes, it doesnt look as if the arm can be repaired, does a new motor come with a new arm or part of, it is arkward to get to and fixed on with 6mm bolts
    any light shed on this would be welcomed.
    thanks
  2. Re: climate control problem
    Dec 2007
  3. Re: climate control problem
    Jun 2008
    Western Europe
    Hello,
    I had exactly the same problem last week.Its posted on this forum somewhere.
    You will need to replace the motor as the yellow arm is fixed
    to it.It is held on by 3 8mm bolts,quite awkward to remove.
    A new motor from audi is £90.but I got one from a breakers for £10.
  4. Re: climate control problem
    Jan 2009
    Hello
    I have just noticed this problem in my car, could you please tell me which panel you removed to check the motor?
  5. Re: climate control problem
    Jun 2008
    Western Europe
    Helllo, Remove the panel at your knees just above the pedals.Its the one that holds the car handbook.When you remove it,be careful
    to unclip the diagnostic socket.
    Once this panel is out of the way look upwards and you will see the motor on the side of the heater unit.It is held on with 3 very small bolt head screws
  6. Re: climate control problem
    May 2008
    Quote Originally Posted by shahid8850 View Post
    Hello
    also remove end of dash panel (visible when door opened) to reveal screws to remove panel above pedals.
    I found a long flexible shaft screwdriver with a socket end (6mm i think)
    very useful. or a small ratchet arm socket with a hex fitting and 6mm socket
    I got motor from online breaker for £40, new from motor factors was £95.
    arkward to get to, i laid a board outside the car supported by blocks to raise it to sill level then laid face up into the footwell, this was more comfortable than arching your back over sill. hope u get on ok
  7. Re: climate control problem
    Jan 2009
    I have had a look i dont know really where or what i am looking for when the cover is removed. Does anyone have a picture showing where it is?
  8. Re: climate control problem
    Dec 2007
    Bedford
    Quote Originally Posted by tpb234 View Post
    I have looked throught my service reports from when the car was new and the previous owner also had this problem... I am not sure what the fix was though as it has not been put on the report
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  1. Please Help Need help with climate control demister
    By tsunami in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-11-2010, 10:25 PM
  2. 2002 a4 climate control/ demist problem
    By graham71 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2009, 07:58 PM
  3. A4 B6 Aircon / climate control problem
    By aphilmor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2009, 10:43 AM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
