Thread: Vag Com codes
Results 1 to 8 of 8
  1. Vag Com codes
    Just managed to get vagcom to work and wondered if anybody could shed some light on the messages / codes that came up?
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 028 906 021 CE
    Component: 1.9l R4 EDC 00SG 0803
    Coding: 00002
    Shop #: WSC 06187
    3 Faults Found:
    00519 - Intake Manifold Pressure Sensor (G71)
    28-00 - Short to B+
    00513 - Shareware Version. To Decode all DTCs
    03-10 - Please Register/Activate - Intermittent
    17978 - Shareware Version. To Decode all DTCs
    P1570 - 35-10 - Please Register/Activate - Intermittent
    Readiness: N/A
  2. Re: Vag Com codes
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    The Address Code relates to the Number that VW have given that particular ECU.ie: 01=Engine Electrics.
    Controller is the Part Number of the interogated ECU.
    Component is the item in question ie: 1.9 EDC(electronic diesel control),and reference number.
    Coding is what spec. its coded to depending on vehicle.
    Shop is the Diagnostic Computer which coded the ECU.
    The fault codes are listed next,alongside a breif description.
    Readiness relates to wether the vehicle has completed a `full driving cycle `to determine if everything is in order,basically a `Self Check`.
    Hope this clears a few things up for you.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Vag Com codes
    Thanks for the reply. Was rather hoping somebody could tell me what the fault codes mean?
  4. Re: Vag Com codes
    Nov 2008
    20 Post(s)
    Oh,well at least it was a typing excercise for me then.
    Alan.
  5. Re: Vag Com codes
    Sorry, didn't mean to sound ungrateful. Thanks for your help :-)
  6. Re: Vag Com codes
    Southern County Softy
    20 Post(s)
    Check the codes on the wiki
    http://wiki.ross-tech.com/index.php/Main_Page
    A4 2.5 tdi QS (mapped)
  7. Re: Vag Com codes
    Nov 2008
    20 Post(s)
    Quote Originally Posted by pg20 View Post
    No,i didnt take your comment the wrong way! Me goin over the top more like,and not answering wot was asked!! LOL
    Alan.
  8. Re: Vag Com codes
    131 Post(s)
    1973 Post(s)
    00519 Intake manifold pressure sender -G71. Short to positive
    1) Open circuit or short circuit
    2) G71 defective
    = Loss of power > Check intake manifold pressure sender
    00513 Engine speed sender -G28
    a) Implausible signal
    i) Sensor disc bent or loose
    ii) G28 defective
    iii) Open circuit in screening
    b) No signal
    i) G28 defective
    ii) Open circuit or short circuit
    1) Engine will not start
    2) Engine cuts out
    3) Glow plug warning lamp flashes
    Remove oil sump and check sensor disc
    Check engine speed sensor
    17978 Engine control unit disabled
    1) Attempted tampering
    2) Immobiliser not adapted
    3) Immobiliser defective
    Engine starts but cuts out again immediately
    Scan immobiliser
    Adapt electronic immobiliser to engine control unit
  1. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. vag engine codes
    By akas in forum Archive posts
    Last Post: 13-09-2007, 12:06 AM
  4. vag engine codes
    Last Post: 10-09-2007, 09:46 PM
  5. VAG COM Login codes
    By Dune in forum Audi A4 - Archive Topics
    Last Post: 10-05-2007, 11:34 PM
