Thread: Q5 Towbar fitting
Results 1 to 10 of 13
  1. Q5 Towbar fitting
    Usk Gwent
    Just went to get a Westfalia towbar fitted today. Ordered it through a reputable firm. The Audi garage used them to fit the towbar on my Q7. However the firm said that there was an issue with fitting towbars on the Q5. Apparently they have to change the fans on the ECU otherwise you get all sorts of weird Electronic issues. It seems to be an attempt by Audi to control the after sales market.
    Wondered if anyone knows anything about this. It seems insane that I have to pay £2,000 or more for a towbar.
    Phil
  2. Re: Q5 Towbar fitting
    Sep 2008
    Buckinghamshire
    Quote Originally Posted by MrPhilT View Post
    Phil
    This is the same for A4, A5 & Q5 - You need a new fan and I believe the back of the car needs strengthing - I know its to late now but for these vehicles factory fit is a must
    Current - Audi A3 Sportback 1.8T Sline
    Gone - Audi S3 Sportback Black Edition, Audi S4 Saloon,
    Why not join the Audi A3 Owners Club
  3. Re: Q5 Towbar fitting
    May 2007
    knee deep in clunge
    14 Post(s)
    I have covered this in depth in the B8 forum for part numbers and which models
    https://www.vwaudiforum.co.uk/forum/s...hlight=tow+bar
  4. Re: Q5 Towbar fitting
    Feb 2010
    Devon, UK
    Where did £2000 come from for the tow bar from Audi - in the 09/10 brochure for the current the Towing Equipment is £650.
    No mention of strengthened rear-end, or uprated fans. Sounds like rubbish if you ask me!
  5. Re: Q5 Towbar fitting
    Sep 2008
    Buckinghamshire
    Quote Originally Posted by slime101 View Post
    No its £2000 to fit if you do not get it from Audi as a Factory fit so £650 is a bargin
  6. Re: Q5 Towbar fitting
    Feb 2010
    Devon, UK
    As ok, i wasnt sure.
    What about aftermarket though, can anyone actually confirm these upgrades to fans and stuff??
    Also when it mentions tow equipment in the brochure it says manual and swivelling....*** does that mean?
  7. Re: Q5 Towbar fitting
    Apr 2013
    Nottingham
    Quote Originally Posted by onemanparty View Post
    I ordered a Q5 with a factory bar but found a major problem - unless the car and caravan is in line and on the level (not possible on most sites) there is not enough room to get the stabiliser caravan hitch on and off as it hits the bumper, neither the supplier or audi has the answer (found them both unhelpful and slow to respond)From the centre of the ball to the rear number is 63mm, not sufficient for a large stabiliser caravan hitch! Not a great situation as I bought the car to tow my caravan.
  8. Re: Q5 Towbar fitting
    Mar 2008
    Hi, been reading some confusion regarding cooling upgrades to Q5's. Some are saying after 2011MY no cooling upgrade was required, is that correct? I have a sept 2011 registered Q5 and considering towing a caravan. I have read a8tech's post but too confusing to me at this time of night. If we are talking £2k for an upgrade the caravan thing might be a no-no. Any advice appreciated. Thanks
    2005 Audi A3 Sport 1.9 TDi, Cherry Red Pearl, 6CD Multichanger, Multi-function sterling wheel, Telephone Prep
    2011 Audi Q5 S-Line 2.0 TDi Quattro, Daytona Grey Pearl, Interior Light Pack, 3 Zone Climate, AMI, Comfort Pack
  9. Re: Q5 Towbar fitting
    Feb 2009
    Hi Moonshadow,
    If your Q5 is indeed a 2011 then it will have all of the necessary upgrades as standard (This was done a standard from Sept 2010 I believe), the easiest way to check is to look in the right hand rear pannel for two plugs wrapped in foam. These are the Tow prep harnesses (1 for tow lights and standard electrics, the other plug for 2nd electrics i.e. fridge power) which means that the fans have been upgraded too.
    I fitted a Thule removable towbar myself, it took all of 1 hour and was super simple. Just remember some one will need to VCDS / VAGCOM your car to code it for rear parking sensors etc.
  10. Re: Q5 Towbar fitting
    Dec 2014
    Wendover, UK
    Had my tow bar fitted by a third party company who came to my work. Great job and now happly using it. Not had any problems at all.
  1. Golf Mk5 Tow Bars - Q&A - All you need to know Guide!! Advice, Tips...
    By Ben in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 03-10-2018, 01:05 AM
  2. Fitting a towbar to an Allroad
    By WesleyP in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-09-2009, 05:25 PM
  3. Golf mk 3 (1996) towbar fitting issues.
    By Lefthander in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 12-08-2008, 09:25 PM
  4. A4 towbar - fitting question
    By bruce1 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 30-04-2008, 09:50 PM
  5. The new Audi Q5: Sporty and versatile
    Last Post: 19-04-2008, 02:25 PM
