Thread: Mk6 2.0TDI with DSG remapping
Results 1 to 10 of 11
  1. Mk6 2.0TDI with DSG remapping
    May 2009
    Manchester
    My GT has the 130 motor & I am thinking of remap to 170/190.
    Three questions - does any one know whether the standard fitted DSG is happy to take the increased output?
    And - has anyone 'played' with their mapping on this engine with good result? If so, can you recommend a supplier/fitter?
  2. Re: Mk6 2.0TDI with DSG remapping
    Feb 2007
    A GTI owner had his DSG remapped by REVO to around 260bhp, and other than a short period where the DSG had to relearn the power delivery (resulting in less smooth shifts), then no issues.
    I'd look at the REVO claims for the torque on the GTI 2.0TFSI engine and use that as a potential maximum figure. It's the torque figure you have to be wary of in terms of gearbox protection. Its not all about big numbers !
    Editted to say - i found another thread from a 1.4TSI 160 owner who had his DSG 7 speed car 'bluefinned' - superchips reckoned 250nm was the max torque for the gearbx. However, given that the std TDI140 engine is 238ftlbs/320NM i guess they meant 250ftlbs max, not 250Nm max !!
  3. Re: Mk6 2.0TDI with DSG remapping
    May 2009
    Manchester
    Good info Percymon - (Yes you are right, my motor is a 140 not 130!)
    238 to 250 isn't much of a torque increase so is it really worth the bother. Or could this refer just to the 7 speed. Could the 6 speed be a stronger box or are they basically the same. May be an email to Superchips would give me a clue.
  4. Re: Mk6 2.0TDI with DSG remapping
    Jul 2009
    Melbourne Australia
    Quote Originally Posted by Rennie Mc/r View Post
    The 6-speed is a stronger box — the 7-speed can't reliably handle the TDI's torque.
  5. Re: Mk6 2.0TDI with DSG remapping
    Mansfield, UK
    Idle is correct, keep the torque to around 400Nm and you should be perfectly OK.
    If you are interested in having your Golf remapped, then we can do this at our base in Mansfield and soon our STS unit will support it too
  6. Re: Mk6 2.0TDI with DSG remapping
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    I've heard that you can remap the TDi from 140 to 195. You could go more but the gearbox can't stand the extra torque. The same goes for the DSG box. Also the clutch doesn't last as long. You can get uprated clutches but these are very expensive.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  7. Re: Mk6 2.0TDI with DSG remapping
    Mansfield, UK
    I think 195bhp is somewhat optimistic, particularly if you like your turbo and injectors.
  8. Re: Mk6 2.0TDI with DSG remapping
    May 2009
    Manchester
    Thanks shark 90. So what kind of figures (bhp / torque) would you (safely) remap to for the 6 sp DSG?
  9. Re: Mk6 2.0TDI with DSG remapping
    Mansfield, UK
    Our website is out of date (that's nearly a full time job in itself!!) and so the Mk6 details aren't on there yet, however you'd be looking at 175bhp and 400Nm torque.
  10. Re: Mk6 2.0TDI with DSG remapping
    May 2009
    Manchester
    Mmm, sounds rather interesting. I may well contact you at Shark. Many thanks.
  1. Please Help 2.0tdi dsg stalling
    By gisexer in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-10-2009, 08:39 AM
  2. 2.0Tdi DSG passat sport saloon (140PS) - engine noise -
    By Mick_OC1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2009, 02:37 PM
  3. Question Broken rear spring on 21K '05 2.0TDI DSG
    By Hillbeley in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-04-2009, 06:50 PM
  4. Replies: 0
    Last Post: 22-12-2007, 03:29 PM
  5. 2.0tdi remapping
    By jc2402 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-06-2007, 11:29 PM
