Thread: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
Results 1 to 9 of 9
  1. Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    milton keynes
    hi please could somebody help me!
    As mentioned above my car makes a sound much like a vacuum from under the bonnet when ignition turned off even after short drives. This would lead me to think the car is over heating....so i have checked the coolant levels which is all fine and the gage inside the car both for coolant level and car temperature is all fine. So not really sure what to make of it, all i know is that it doesnt sound healthy and its definately getting worse.
    Any ideas / tips???
  2. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    Pembrokeshire
    22 Post(s)
    turn engine off and lift bonnet. listen carefully and try to locate the noise. a length of rubber pipe pressed into the ear can help to pinpoint it. it could be a split vacuum pipe.which engine do you have?
  3. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    milton keynes
    thanks for the reply its a 04 plate 2L FSI.
  4. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    milton keynes
    how can i check if its the vacuum pipe causing the propblem?
  5. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by mad_kows2 View Post
    What kind of noise exactly? A hissing (like an air/vacuum leak)? Or do you mean the noise sounds a bit like a vacuum cleaner? If it's the latter, it could be your cooling fan running on - a fairly common problem, cured by fitting a new twin fan/controller pack.
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  6. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    milton keynes
    it really does sound like a vacuum cleaner : S!! Short of taking it to a garage and paying do you know how i could check if its this and if it was roughly how much would it cost to replace the twin fan/controller pack??
    thanks
  7. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    May 2009
    69 Post(s)
    Open the bonnet and you should be able to see if one (or both) of the cooling fans are running. If they are, and they switch off after a minute or two, it may be that nothing is wrong, although if this happens all the time and/or the fans do not switch off, it probably means that the fan controller is faulty.
    If this is the case, unfortunately the controller cannot be replaced on its own - it comes as part of a kit to replace the twin fans. Cost of the fan pack is just over £200, plus the cost of fitting it - budget for around the £300 mark in total.
    Here are examples of similar threads...
    https://www.vwaudiforum.co.uk/forum/showthread.php?t=68633
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=75120
    MF.
  8. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    uk
    this happened to my car - only after i had the air con/heaters on tho. Does it happen without the air con/heaters on?
  9. Re: Vacuum sound coming from under the bonnet after ignition is turned off even after only short drives
    milton keynes
    yup it happens withoutout the air con/heaters on. Ive managed to get it looked at for free......turns out it has a leak in the radiator : S..... i havent got the quote yet but i am under the impression replacing radiators is a pricey job!?!?
  1. Question Sound Insulation in engine bay
    By Manutor in forum Jetta MK3 - 2005 - 2013
    Last Post: 01-05-2009, 07:23 PM
  2. Key Question - HELP!!!
    By simonjf in forum Archive posts
    Last Post: 16-06-2007, 11:33 PM
  3. Key Coding
    By bbb in forum Passat - Archive Topics
    Last Post: 25-03-2007, 10:08 PM
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
