Thread: Passat fault Code: 18034 Powertrain data bus: Missing message from tcu
  1. Passat fault Code: 18034 Powertrain data bus: Missing message from tcu
    Apr 2007
    Ran a scan via vag-com and it came with that fault code.
    Its a VW Passat 2000 W reg Auto. When i drive the car from cold then the gear shift from 1st to 2nd and 2nd to first is a bit jerky.
    However once its warm then it works perfectly.
    Any idea on what might be the problem? Thanks.
    Apr 2007
    As it happens the passenger side front carpet is pretty damp. The TCM is under the carpet, havent had a look at it yet.
    Dumb question, but how do I take the carpet off to have a look at the TCM? How do get rid of the dampness? And hw do I identify the source?
    I am asking this, as Ive heard this is a pretty common problem and someone here must have gone through this so their help would be greatly appreciated.
  1. Fault code
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 08:41 PM
  2. Fault code reader
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 10:31 AM
  3. mk4 tdi missing, cold start,ecu fault
    By dyl_55 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2007, 03:26 PM
  4. MK 3 Gti 16v Fault Code - ABS Problem
    By dravidham in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
  5. Fault Code 058F - Help!
    By Nuggs in forum Chat - Completely Off Topic
    Last Post: 24-04-2006, 02:58 PM
