Thread: afb v ake whats the difference in engine apart from power
  1. afb v ake whats the difference in engine apart from power
    Dec 2007
    hi all
    well got heads off tho find that as well as cams it needs new head and piston. here's what i need to know.
    i can get a complete AFB engine so will it fit my 2.5 tdi quatro AKE 180hp car, i think to go from 150 to 180 its the turbo and injectors.
    or i can rebuild my engine so is the pistons the same for the 150 and 180 also are the pistons different from left bank to right bank as i only need 1 its looking at car middle piston right bank.
    I'm in a total quandry here i cant sell car the way it is so ive got £1100 to repair car or £1050 to change complete engine whats the best way to go need help urgent got 24hrs to decide
    Sharan 1999 1.9tdi 110 afn
  2. Re: afb v ake whats the difference in engine apart from power
    The AFB engine has a bigger compression ratio than the AEK engine.Both engines have the same bore and stroke measurements,so the only thing i can think of for the difference in comp ratio is the hight of the pistons or a different head gasket.However i think your main problem is that they have different control units,hence,different wiring harness,and mucho problemos
  3. Re: afb v ake whats the difference in engine apart from power
    Jan 2009
    Falmouth, UK
    I strongly suggest you stick with AKE. There are many difference between the 2 engines and i fear you may spend a lot of time and money chasing the mismatches around before you get everything running again.
    2001 Audi A6 2.5TDI Avant quattro Sport, Celtic Tuning remap, TurboDynamics MD438 hybrid turbo, 3" decatted Longlife stainless exhaust, Bosio Race683 nozzles
    2004 Audi A4 1.9TDI Avant quattro + Superchip
    1988 Yamaha FJ1200
  4. Re: afb v ake whats the difference in engine apart from power
    Dec 2007
    ive left it well a be and decided to fix car. now then for intrest its cheaper to get all my parts from audi than any motor factor i use fathom that out eg:
    head gasket audi £21 factors £37
    piston audi £121 factors from £180 plus del plus vat
    may be worth a visit if any one needs to fix car
  5. Re: afb v ake whats the difference in engine apart from power
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by zorgman View Post
    So... always try the dealer for prices.
    They don't always ride a horse and hold up coaches
    A4 2.5 tdi QS (mapped)
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  3. Answers From The Oil Expert Part 2
    Last Post: 22-10-2007, 08:30 AM
  4. How does the Quattro system work?
